    How to send a notification
    35 Posts 3 Posters 11.9k Views 3 Watching
      sdetweil @Alyx
      @alyx nice, but you missed one key point
      and this stuff goes in the alexacontrol module
      config:{}
      section
      u have in the general module section not in the module config
      A 1 Reply Last reply
      • A
        Alyx @sdetweil
        @sdetweil Ah! that worked thanks :) Next issue it doesnt call the module when activated lol
          sdetweil @Alyx
          @alyx so, now open the developers window, ctrl-shift-i, and look at the console tab
          u may be able to see some module report the notification
          or install my samplemodule as it reports all notifications received
          https://github.com/sdetweil/SampleModule
          in the Alexa app u can control devices manually, so that makes testing a lot easier
          • A
            Alyx @sdetweil
            @sdetweil Hi sam,
            Great so i can see that the notification isnt being sent via the dev console, it shows up via Alexa app but isnt communicating to the MM. Would you happen to know the cause?
                    module: 'MMM-AlexaControl',
                    position: 'middle_center',
            	config:{
                        image: true,
            	    deviceName: "mirror",
                        pm2ProcessName: "mm",
                        vcgencmd: "hide",
            	    startPort: 11001,
            	    refresh: true,
            	    restart: true,
            	    //stop: true,
            	    reboot: true,
            	    shutdown: true,
            	    monitorToggle: true,
            	    //cecAddress: "0.0.0.0",
            	    //usb: false
            	    pages: 3,
            	    notifications:[
                    port: 11102,
                    OnOff: false,
                    notification: ["PAGE_INCREMENT", 'payload']
                    port: 11103,
                    OnOff: false,
                    notification: ["PAGE_DECREMENT", 'payload']
                    port: 11104,
                    OnOff: false,
                    notification: ["SELFIE_SHOOT", 'payload']
              sdetweil @Alyx
              @alyx not really. if u stop MagicMirror, and then tell Alexa to turn on your notification device, you should get a ‘not responding’ message from alexa
              that will tell you the two are really connected.
              Alexa turn on selfie
              • A
                Alyx @sdetweil
                @sdetweil Yep that makes sense but it isnt popping up below is a quick snapshot of the dev panel
                MMM-MotionDetector.js:75 MMM-MotionDetector: DiffCamEngine init successful.
                module.js:195 MMM-AlexaControl is suspended.
                module.js:195 MMM-NASA is suspended.
                module.js:195 MMM-ISS-Live is suspended.
                module.js:195 MMM-MotionDetector is suspended.
                module.js:195 lifecounter is suspended.
                module.js:195 compliments is suspended.
                module.js:195 MMM-chromecast is suspended.
                MMM-NASA.js:132 Hailing NASA
                module.js:202 MMM-page-indicator is resumed.
                module.js:202 MMM-Selfieshot is resumed.
                module.js:202 MMM-Astro is resumed.
                module.js:202 MMM-MoonPhase is resumed.
                module.js:202 clock is resumed.
                eventtracking-log.services.video.ibm.com/eventtracking.web.player/:1 Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
                MMM-AlexaControl.js:75 RECEIVE monitor NOTIFICATION=SLEEP_WAKE
                MMM-AlexaControl.js:75 RECEIVE monitor NOTIFICATION=SLEEP_HIDE
                MMM-pages.js:97
                The errors lead to this page
                400 Bad Request
                ‘json’ or ‘msgpack’ parameter is required
                  sdetweil @Alyx
                  @alyx said in How to send a notification:
                  one thing at a time
                  you didn’t answer the question about connection
                  • A
                    Alyx @sdetweil
                    @sdetweil Apoligies, tested there.
                    So I stopped magic mirror/ restarted the pi and it came up with device unresponsive.
                      sdetweil @Alyx
                      @alyx ok, and when MM is running you get the completion sound from alexa, correct?
                      • A
                        Alyx @sdetweil
                        @sdetweil what do mean by a completion sound? Do you mean the confirmation of ‘ok’ after? If so then yes
                          sdetweil @Alyx
                          @alyx when u turn on or off a device, alexa does tada sound… to says it processed your request
                          • A
                            Alyx @sdetweil
                            @sdetweil ah my one says ‘ok’ but id assume its the same
                              sdetweil @Alyx
                              @alyx I added your config to my MM and added debugging… and it works as expected
                              samplemodule reports Selfie_shoot was received
                              SampleModule received a module notification: SELFIE_SHOOT from sender: MMM-AlexaControl
                              and because u have is as onOff:false
                              u get a notification every time (on or off)
                              I did this using the alexa app…
                              • A
                                Alyx @sdetweil
                                @sdetweil oh… where do you think I went wrong so?
                                  sdetweil @Alyx
                                  @alyx i don’t know… i didn’t change anything in your config…
                                  if you use the alexa app to turn the plug on or off, do you see the notifications?
                                  • A
                                    Alyx @sdetweil
                                    @sdetweil ok I re added the selfie device on the alexa app and it found it fine but its now coming up as unresponsive
                                      sdetweil @Alyx
                                      @alyx so, discovery records the IP address of the ‘device’ and the port.
                                      so, if your pi changes ip address during boot, then it won’t work again …
                                      all my pi type devices have fixed addresses to avoid this problem…
                                      • A
                                        Alyx @sdetweil
                                        @sdetweil ah ok I’ll set a static! TBH I did have that concern but i was wrong to assume it was dynamic with the IP’s
                                        I’ll come back if this works or not , I have a call rn
                                          sdetweil @Alyx
                                          @alyx yeh the Alexa design is devices don’t move around, and one would only do discovery occasionally
                                          then u have to delete the devices and rediscover
                                          • A
                                            Alyx @sdetweil
                                            @sdetweil ok so after fighting with my interfaces file for a few days I have a static IP
                                            Only issue is that I can discover devices on the Alexa app but they arent usable and just come up an unresponsive…
                                            It seems the static IP has messed with that feature ? Any advise on this please?
