    notificationFx.css
    8 Posts 2 Posters 1.7k Views 2 Watching
      Ray
      So I have a dilemma that I don’t quite know how to solve
      currently in my custom.css . I have the settings for the alert module which uses the notificationFx.css. And it works perfectly.
      .ns-box {
        background-color: rgba(0, 0, 0, 0.5);
        padding: 17px;
        line-height: 1.4;
        margin-bottom: 10px;
        z-index: 1;
        font-size: 70%;
        position: relative;
        display: table;
        word-wrap: break-word;
        max-width: 100%;
        border-width: 1px;
        border-radius: 5px;
        border-style: solid;
        border-color: var(--color-text-dimmed);
      .ns-box .dimmed {
          color: #00FFFF;
      .ns-box .normal {
          color: #ffffff;
      .ns-box .bright {
          color: #00FF00;
      The problem is my new module MMM-StopwatchTimer uses exactly the same alert notificationFx.css
      I don’t want to have the same settings the same colors. How do I fix this problem
      Any help would be appreciated
        sdetweil @Ray
        @ray I think if u add the modulename as the start of each class, that will override the general case
        alert .ns-box {…
        note the space between alert and .ns-box
        repeat for all the classes that apply
          Ray @sdetweil
          @sdetweil I think I tried that but I’ll try again
            Ray @sdetweil
            @sdetweil when I added it to the 1st 1 it worked
            but when I added to the other 3 everything is in black and white now
            .alert .ns-box  {        /*ns-box is for Alert. It displays notifications for other modules.*/
              padding: 17px;
              line-height: 1.4;
              z-index: 1;
              font-size: 70%;
              position: relative;
              display: table;
              max-width: 100%;
              border-width: 1px;
              border-radius: 5px;
            .alert .ns-box .dimmed {     /* Header MagicMirror */
                color: #00FFFF;
            .alert .ns-box .normal {     /* */
                color: #ffffff;
            .alert .ns-box .bright {     /* Welcome start was successful */
                color: #00FF00;
            is it because I have
            dimmed
            normal
            bright
            should there be a – there instead of . Maybe
            I should’ve included these in my 1st reply sorry
              sdetweil @Ray
              @ray
              . (dot) means class
              no dot means html element (li, ul, div, span…)
              that should have worked
              this
              means ALL the .normal classes, INSIDE .ns-box classes , inside .alert classes
                Ray @sdetweil
                @sdetweil said in notificationFx.css:
                If I set it up just like this. It works
                but the 3 items below my new module will use them, which I do not want
                  padding: 17px;
                  line-height: 1.4;
                  z-index: 1;
                  font-size: 70%;
                  position: relative;
                  display: table;
                  max-width: 100%;
                  border-width: 1px;
                  border-radius: 5px;
                .ns-alert .dimmed {     /* Header MagicMirror */
                    color: #00FFFF;
                    color: #ffffff;
                    color: #00FF00;
                if I set it up like this. Everything is black and white. except for the box it will be black and the text will be white
                  padding: 17px;
                  line-height: 1.4;
                  z-index: 1;
                  font-size: 70%;
                  position: relative;
                  display: table;
                  max-width: 100%;
                  border-width: 1px;
                  border-radius: 5px;
                    color: #00FFFF;
                    color: #ffffff;
                    color: #00FF00;
                I cannot see what I’m doing wrong here
                  sdetweil @Ray
                  @ray said in notificationFx.css:
                  but ALL the custom classes need .alert in front
                  only use for alert
                  sorry, didn’t scroll down
                  open the developers window, ctrl-shift-i, select the elements tab, click the pointer top left and navigate to the content in the left pane, and you will see the classes tree on the right… top is closest to the module, bottom is more global
                    Ray @sdetweil
                    @sdetweil yes I just did that I sent you a copy of it
