notificationFx.css
8 Posts 2 Posters 1.0k Views 2 Watching
    Ray
    So I have a dilemma that I don’t quite know how to solve
    currently in my custom.css . I have the settings for the alert module which uses the notificationFx.css. And it works perfectly.
    .ns-box {
      background-color: rgba(0, 0, 0, 0.5);
      padding: 17px;
      line-height: 1.4;
      margin-bottom: 10px;
      z-index: 1;
      font-size: 70%;
      position: relative;
      display: table;
      word-wrap: break-word;
      max-width: 100%;
      border-width: 1px;
      border-radius: 5px;
      border-style: solid;
      border-color: var(--color-text-dimmed);
    .ns-box .dimmed {
        color: #00FFFF;
    .ns-box .normal {
        color: #ffffff;
    .ns-box .bright {
        color: #00FF00;
    The problem is my new module MMM-StopwatchTimer uses exactly the same alert notificationFx.css
    I don’t want to have the same settings the same colors. How do I fix this problem
    Any help would be appreciated
    S 1 Reply Last reply Nov 22, 2021, 5:36 PM Reply Quote 0
      sdetweil @Ray
      @ray I think if u add the modulename as the start of each class, that will override the general case
      alert .ns-box {…
      note the space between alert and .ns-box
      repeat for all the classes that apply
      R 2 Replies Last reply Nov 22, 2021, 5:50 PM Reply Quote 0
        Ray @sdetweil
        @sdetweil I think I tried that but I’ll try again
          Ray @sdetweil
          @sdetweil when I added it to the 1st 1 it worked
          but when I added to the other 3 everything is in black and white now
          .alert .ns-box  {        /*ns-box is for Alert. It displays notifications for other modules.*/
            padding: 17px;
            line-height: 1.4;
            z-index: 1;
            font-size: 70%;
            position: relative;
            display: table;
            max-width: 100%;
            border-width: 1px;
            border-radius: 5px;
          .alert .ns-box .dimmed {     /* Header MagicMirror */
              color: #00FFFF;
          .alert .ns-box .normal {     /* */
              color: #ffffff;
          .alert .ns-box .bright {     /* Welcome start was successful */
              color: #00FF00;
          is it because I have
          dimmed
          normal
          bright
          should there be a – there instead of . Maybe
          I should’ve included these in my 1st reply sorry
          S 1 Reply Last reply Nov 22, 2021, 6:11 PM Reply Quote 0
            sdetweil @Ray
            @ray
            . (dot) means class
            no dot means html element (li, ul, div, span…)
            that should have worked
            this
            means ALL the .normal classes, INSIDE .ns-box classes , inside .alert classes
            R 1 Reply Last reply Nov 22, 2021, 6:31 PM Reply Quote 0
              Ray @sdetweil
              @sdetweil said in notificationFx.css:
              If I set it up just like this. It works
              but the 3 items below my new module will use them, which I do not want
                padding: 17px;
                line-height: 1.4;
                z-index: 1;
                font-size: 70%;
                position: relative;
                display: table;
                max-width: 100%;
                border-width: 1px;
                border-radius: 5px;
              .ns-alert .dimmed {     /* Header MagicMirror */
                  color: #00FFFF;
                  color: #ffffff;
                  color: #00FF00;
              if I set it up like this. Everything is black and white. except for the box it will be black and the text will be white
                padding: 17px;
                line-height: 1.4;
                z-index: 1;
                font-size: 70%;
                position: relative;
                display: table;
                max-width: 100%;
                border-width: 1px;
                border-radius: 5px;
                  color: #00FFFF;
                  color: #ffffff;
                  color: #00FF00;
              I cannot see what I’m doing wrong here
              S 1 Reply Last reply Nov 22, 2021, 6:33 PM Reply Quote 0
                sdetweil @Ray
                @ray said in notificationFx.css:
                but ALL the custom classes need .alert in front
                only use for alert
                sorry, didn’t scroll down
                open the developers window, ctrl-shift-i, select the elements tab, click the pointer top left and navigate to the content in the left pane, and you will see the classes tree on the right… top is closest to the module, bottom is more global
                R 1 Reply Last reply Nov 22, 2021, 6:35 PM Reply Quote 0
                  Ray @sdetweil
                  @sdetweil yes I just did that I sent you a copy of it
