    Diego Vieria Random-Photo read image from PI ?
    13 Posts 3 Posters 8.7k Views 3 Watching
      alverman
      But where put the folder address ?
      In RandomBackground.js ?
      // Additional folders to find photos in
      in this mode:
      photoDirectories: [images]
      Thanks, Alberto
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @alverman
        @alverman currently a custom path is not implemented yet.
        the images should be placed in this directory MagicMirror/modules/MMM-RandomBackground/photos/
          alverman
          Ah OK !!
          But when active this module in config.js I see all black !!
          In photos directory I have 3 png images !!
          why ?
          Thanks, Alberto
          • U Offline
            Ultimatum22 Module Developer
            Please post the part of the config file you have added for this module. Also did you look in the log and/or browser console? Without any info it’s near impossible to help.
              alverman
              And in dev mode I have 1 error:
              failed to load http://localhost:8080/modules/RandomBackground//RandomBackground.js
              resource: the server responded with a status of 404 (non found)
              • U Offline
                Please show your config, I am assuming your either did something wrong there. Also how did you add this module? The folder and js file are wrong, should be MMM- before it.
                  alverman
                  You were right !!
                  I had forgotten to put in the MMM- config.js
                  But now I have another error when I npm install I get:
                  Succeffully applied Snyk Patches
                  npm grunt-yamllint@0.2.0 WARN requires a peer of grunt@tilde0.4.0 but none installed
                  While in the dev box now I get:
                  http: // localhost: 8080 / modules / MMM-RandomBackground // node_modules / jquery / dist / jquery.min.js
                  Failed to load resource: the server responded with a status of 404 (not found)
                  my config.js is:
                  /* Magic Mirror Config Sample
                  • MIT Licensed.
                  var config = {
                  port: 8080,
                  language: 'it',
                  timeFormat: 24,
                  units: 'metric',
                  		module: 'alert',
                  		module: 'clock',
                  		position: 'top_left',
                  			//displayType: 'analog',
                  			//analogSize: '150px',
                  			clockBold: 'true',
                  		module: 'calendar',
                  		header: 'Italy Holidays',
                  			symbol: 'calendar-check-o ',
                  			url: 'webcal://www.calendarlabs.com/templates/ical/Italy-Holidays.ics'
                  		module: 'compliments',
                  		position: 'lower_third'
                  		module: 'currentweather',
                  		position: 'top_right',
                  			locationID: '',  //ID from http://www.openweathermap.org
                  			appid: 'bd58e4e078cdfc75d925db0884834114'
                  		module: 'weatherforecast',
                  		header: 'Weather Forecast',
                  			locationID: '5128581',  //ID from http://www.openweathermap.org
                  		module: 'newsfeed',
                  		position: 'bottom_bar',
                  			feeds: [
                  				title: "Repubblica",
                  				url: "http://www.repubblica.it/rss/cronaca/rss2.0.xml"
                  			showSourceTitle: true,
                  			showPublishDate: true
                  	        module: 'MMM-ImageDisplay',
                  	            image: 'Amore_1.png', // Name of the image (including file extension) here, place image in '/images/' folder
                  	            maxWidth: '20%', // Optional, possible values: absolute (e.g. '20px') or relative ('50%')
                  	            maxHeight: '200%', // Optional, use absolute values (e.g. '30px', '100px')
                  	        position: 'bottom_right'    // This can be any of the regions.
                  		module: 'MMM-Instagram',
                  		position: 'top_center',
                  		access_token: '3231895908.1677ed0.48b0c4acc7a74f1d86a404a4a5616457',
                  		count: 200,
                  		min_timestamp: 0,
                  		animationSpeed: 5500,
                  		updateInterval: 12500
                  module: ‘MMM-RandomPhoto’,
                  position: ‘fullscreen_below’,
                  opacity: 0.3,
                  animationSpeed: 500,
                  updateInterval: 60,
                  url: ‘…/images/Amore_1.png’
                  module: ‘MMM-Remote-Control’
                  , posistion: ‘bottom_left’
                  module: ‘MMM-RandomBackground’,
                  config:{
                  animationSpeed: 1000,
                  updateInterval: 500
                  if (typeof module !== ‘undefined’) {module.exports = config;}
                    alverman
                    All OK !!
                    Work very well … thanks
                    Alberto
                      alverman
                      But if I wanted to see the lower right images, not as a background, for example, what should I change?
                      Thanks for your patience
                      Alberto
                      • U Offline
                        How did you fix it? This could be helpful for other people in the future. For now only full screen background is supported, I might change this in the future.
