    Crontab to Restart Magic Mirror does not work
    11 Posts 3 Posters 3.6k Views 3 Watching
      sdetweil @evroom
      @evroom good catch on the uppercase pm2…
      @Desert-Rat
      everything in Linux is case sensitive
        Desert Rat @sdetweil
        Thanks for the quick reply. I changed the crontab. I actually changed it to PM2 START MagicMirror.
        The process I used was to , via the terminal, pm2 stop MagicMirror. This worked and MagicMirror was stopped sucessfully.
        Crontab was updated as above PM2 START MagicMirror.
        It did not start.
        Here are the entries from the log file
        Nov 27 13:44:01 raspberrypi CRON[3620]: (pi) CMD (SUDO PM2 START MagicMirror)
        Nov 27 13:44:01 raspberrypi CRON[3618]: (CRON) info (No MTA installed, discarding output)
        Nov 27 13:55:01 raspberrypi CRON[3661]: (root) CMD (sudo pm2 restart MagicMirror)
        Nov 27 13:55:04 raspberrypi CRON[3659]: (CRON) info (No MTA installed, discarding output)
        Nov 27 14:17:01 raspberrypi CRON[3772]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
        S evroomE 2 Replies Last reply Reply Quote 0
          sdetweil @Desert Rat
          @desert-rat PM2 is not the command
          pm2 is the command and start is the parm
          all lower case
          • evroomE Offline
            evroom @Desert Rat
            @desert-rat
            Could you please show the crontab ?
            $ crontab -l
            To get rid of this:
            you have to add >/dev/null 2>&1
            Try:
            44 * * * * /usr/local/bin/pm2 start MagicMirror >/dev/null 2>&1
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.31.0
              Desert Rat
              Problem resolved! Outstanding.
              My thanks to all who responded.
              My mission now is to research the provided solution and try to understand why it worked. Clearly the devil is in the details.
              Thanks again to all of you
                @desert-rat said in Crontab to Restart Magic Mirror does not work:
                your crontab entry
                44 * * * * PM2 restart MagicMirror
                the working crontab entry
                could be restart as well…
                simple, two things
                cron runs as root, BUT certain folders are not in the path
                so you need to specify the path to the command
                 /usr/local/bin/
                second the command is pm2, you tried PM2
                in linux EVERYTHING is case sensitive
                so yours is command not found, cause there is no command named PM2
                  @sdetweil Thanks Sam! I clearly need some education. Do you have a favorite set of training documentation for newbies
                  Desert Rat
                    @desert-rat sorry. no idea. my info is gathered over 20+ years
                    there are online linux courses, but I don’t know where they start, or how deep they go, how fast.
                    I have a near photographic memory which is a blessing and a curse…
