    Crontab to Restart Magic Mirror does not work
    11 Posts 3 Posters 4.7k Views 3 Watching
      sdetweil @Desert Rat
      @desert-rat what is in the pm2 log??
      pm2 logs --lines=50
      what user is the cron entry running as?
      typically root…
      but the pm2 entry is setup for pi probably
      • evroomE
        evroom @Desert Rat
        @desert-rat
        I would try pm2 iso PM2.
        And even would advise to use the full path, that can be determined using:
        which pm2
        With Debian it would be /usr/local/bin/pm2
        And you can check this log if cron did anything at all:
        /var/log/syslog
        Or edit /etc/rsyslog.conf and remove comment on the line with cron (around line 63)
        Then the dedicated cron log will be in /var/log/cron.log.
        After editing, restart with „sudo systemctl restart rsyslog“.
        Good luck,
        E.J.
        MagicMirror version: 2.37.0
          sdetweil @evroom
          @evroom good catch on the uppercase pm2…
          @Desert-Rat
          everything in Linux is case sensitive
          D 1 Reply Last reply
            Desert Rat @sdetweil
            Thanks for the quick reply. I changed the crontab. I actually changed it to PM2 START MagicMirror.
            The process I used was to , via the terminal, pm2 stop MagicMirror. This worked and MagicMirror was stopped sucessfully.
            Crontab was updated as above PM2 START MagicMirror.
            It did not start.
            Here are the entries from the log file
            Nov 27 13:44:01 raspberrypi CRON[3620]: (pi) CMD (SUDO PM2 START MagicMirror)
            Nov 27 13:44:01 raspberrypi CRON[3618]: (CRON) info (No MTA installed, discarding output)
            Nov 27 13:55:01 raspberrypi CRON[3661]: (root) CMD (sudo pm2 restart MagicMirror)
            Nov 27 13:55:04 raspberrypi CRON[3659]: (CRON) info (No MTA installed, discarding output)
            Nov 27 14:17:01 raspberrypi CRON[3772]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
            S evroomE 2 Replies Last reply
              @desert-rat PM2 is not the command
              pm2 is the command and start is the parm
              all lower case
              • evroomE
                evroom @Desert Rat
                @desert-rat
                Could you please show the crontab ?
                $ crontab -l
                To get rid of this:
                you have to add >/dev/null 2>&1
                Try:
                44 * * * * /usr/local/bin/pm2 start MagicMirror >/dev/null 2>&1
                  Desert Rat
                  Problem resolved! Outstanding.
                  My thanks to all who responded.
                  My mission now is to research the provided solution and try to understand why it worked. Clearly the devil is in the details.
                  Thanks again to all of you
                    @desert-rat said in Crontab to Restart Magic Mirror does not work:
                    your crontab entry
                    44 * * * * PM2 restart MagicMirror
                    the working crontab entry
                    could be restart as well…
                    simple, two things
                    cron runs as root, BUT certain folders are not in the path
                    so you need to specify the path to the command
                     /usr/local/bin/
                    second the command is pm2, you tried PM2
                    in linux EVERYTHING is case sensitive
                    so yours is command not found, cause there is no command named PM2
                      @sdetweil Thanks Sam! I clearly need some education. Do you have a favorite set of training documentation for newbies
                      Desert Rat
                        @desert-rat sorry. no idea. my info is gathered over 20+ years
                        there are online linux courses, but I don’t know where they start, or how deep they go, how fast.
                        I have a near photographic memory which is a blessing and a curse…
