    MMM-SoccerLiveScore
    187 Posts 37 Posters 339.2k Views 35 Watching
    • N
      np27np27
      @0m4r
      Actually I found another issue after the fix. The scores don’t seem to be updating during games or even at regular intervals.
      I’m not sure if it’s updating at all, maybe only when magicmirror restarts or if I restart the module. @0m4r can you have a look and confirm if it works for you?
      0m4r0 1 Reply Last reply
      • 0m4r0
        0m4r Module Developer @np27np27
        @np27np27 I guess you are correct, something is wrong since the second last update.
        I have tried to reduce the number of API calls trying to have them issued only when games are on or about to start rather than each and every 2 mins… but sometimes things do not work as I expect.
        You should be able to see a message at the bottom of the standings telling you when the next API request is expected to be executed, that should help d figure if the new data are requested at a meaningful time.
        N 1 Reply Last reply
        • N
          np27np27 @0m4r
          @0m4r
          For me the module has an api request date of yesterday! So it’s probably not called the api?
          • 0m4r0
            @np27np27 probably. I have realized I have a mistake when the event is finished and the next date should be set to be used…
            If you manually refresh with F5 or restart does it get any better?
            • N
              np27np27 @0m4r
              @0m4r
              Yes if you manually restart MM the the data updates.
              • 0m4r0
                @np27np27 alright - I will try to fix it, but it may take some time, I usually dedicate time to my side project on the weekend
                • N
                  np27np27 @0m4r
                  @0m4r
                  No problem, thanks for trying and keeping this module going 👍🏾👍🏾
                  • 0m4r0
                    @np27np27 can you try check out and run this branch:
                    https://github.com/0m4r/MMM-SoccerLiveScore/tree/feature/node-fetch
                    > cd [YOUR_PATH_TO_MMM-SoccerLiveScore]
                    > git fetch -p
                    > git checkout feature/node-fetch
                    > git pull -r
                    > npm ci
                    > [RESTART MM]
                    I did do some major changes (removed request for node-fetch, and some other code improvements amongst which I hope to have fixed the problem of the refresh you reported)
                    • N
                      np27np27 @0m4r
                      @0m4r said in MMM-SoccerLiveScore:
                      > git fetch -p
                      > git checkout node-fetch
                      > git pull -r
                      > npm ci
                      > [RESTART MM]
                      Hi @0m4r ,
                      Ive tried the above but got an error at the checkout node-fetch line. Can’t find the file or something similar?
                      Still continued on and did the rest.
                      The mm restart has updated the module data. I will check when a game plays tonight to see if the live data changes.
                      • 0m4r0
                        • 0m4r0
                          @np27np27 said in MMM-SoccerLiveScore:
                          should be:
                          • N
                            np27np27
                            @0m4r
                            OK tried again, this time I received the following after npm ci
                            npm WARN prepare removing existing node_modules/ before installation
                            npm ERR! cipm can only install packages when your package.json and package-lock.json or npm-shrinkwrap.json are in sync. Please update your lock file with npm install before continuing.
                            npm ERR!
                            npm ERR!
                            npm ERR! Invalid: lock file’s node-fetch@2.6.6 does not satisfy node-fetch@v2.6.1
                            npm ERR!
                            npm ERR! /home/pi/.npm/_logs/2021-12-06T22_20_06_917Z-debug
                            .log
                            • N
                              np27np27 @np27np27
                              @0m4r
                              npm ERR!
                              npm ERR!
                              npm ERR!
                              .log
                              I did npm install then npm Ci and it seems no errors this time. Let’s see if it works now. I’ll let you know 👍🏾
                              • N
                                np27np27 @np27np27
                                @0m4r,
                                Looks like it’s still not working. It’s gone past the api call date that is displayed at the bottom of the module and it’s not updated. Does it work for you?
                                • 0m4r0
                                  @np27np27 can you try pulling the code once more? I did mess up the logic to re-issue the API requests, but I hopefully fixed it now!
                                  • N
                                    np27np27 @0m4r
                                    @0m4r
                                    Yes will try later today. Thanks for your continued effort 👍🏾
                                    • 0m4r0
                                      @np27np27 there are probably still some issue, but it seems to me it now updates correctly :)
                                      • N
                                        np27np27 @0m4r
                                        @0m4r
                                        No I don’t think it’s updating for me.
                                        Maybe I need to delete the whole module and start again. I did get a few errors during the update to your new changes.
                                        Can I reinstall from the main branch or do I reinstall and then update again how you mentioned above?
                                        • 0m4r0
                                          @np27np27 I am sorry to hear that :(
                                          you should try again from the feature/node-fetch .
                                          if you see any errors, would you please cut&paste them in here so I can have a look at them?
                                          would you also mind showing me your config for the module?
                                          • N
                                            np27np27 @0m4r
                                            @0m4r
                                            Ok ive reinstalled and successfully updated to the feature/fetch-node branch. I think it all installed error free this time!!
                                            Lets see how things look later today after during the premier league games. I’ll let you know how it goes.
                                            My config for the module:
                                            		disabled: false,
                                            		module: 'MMM-SoccerLiveScore',
                                            		position: 'top_right',
                                            		header: 'Live-Scores',
                                            			leagues: [17],
                                              			showNames: true,
                                             			showLogos: true,
                                             			displayTime: 20 * 1000,
                                              			showStandings: true,
                                              			showTables: true,
                                              			showScorers: false,
                                            • 10
                                            • 8 / 10
