    MMM-Jeedom - align to left
    11 Posts 3 Posters 3.8k Views 3 Watching
      selyjohns
      The module displays information with “CustomTitle” align to left, and value of idx align to right (see on bottom_right)
      For 2 other MMM-Jeedom (positionned on bottom_left), I want the result align to left.
      alt text
      Is it possible ?
      Thank you.
        selyjohns
        With the inspector, I’ve been able to do this :)
        in main.css
        .region.bottom.left .time.align-right
          text-align: left;
        I think it’s not the best optimisation.
        I don’t found how to apply only this parameter to Jeedom module, only on bottom_left.
        Thank you.
          sdetweil @selyjohns
          @selyjohns said in MMM-Jeedom - align to left:
          text-align: left;
          .MMM-Jeedom .time.align-right
            text-align: left;
          • mumblebajM Offline
            @sdetweil said in MMM-Jeedom - align to left:
            text-align: left;
            Should go into custom.css and not main.css right?
              selyjohns
              text-align: left;
              Works great, in custom.css instead main.css :)
              Thank you for your help
                sdetweil @mumblebaj
                @mumblebaj all css goes in custom.css
                never change main.css
                never change any files mm ships
                  selyjohns
                  Hi again,
                  Finally, I’ve a problem.
                  The modification is applied to all jeedom module, not only on the bottom left one.
                  Is anything possible to apply only the align left to the jeedom module on bottom left only ?
                  I want to keep the align right for the jeedom module on bottom_right
                  Thx.
                    sdetweil @selyjohns
                    @selyjohns read this and the next two posts
                    https://forum.magicmirror.builders/topic/15967/weather-vs-weather-forecast-font/2?_=1638979293900
                    #identifier   .time.align-right  {
                    text-align: left;
                      selyjohns
                      text-align: left;
                      yep
                      Works perfectly with the identifier of the two module
                      #module_9_MMM-Jeedom .time.align-right  {
                      text-align: left;
                      #module_10_MMM-Jeedom .time.align-right  {
                      text-align: left;
                      Thank you…again :) !
                      Have a nice week-end
                        sdetweil @selyjohns
                        @selyjohns little warning. if u add a module to the list in front of those two, their identifiers will change
