    MMM-Podcast2 - deprecated package request
    3 Posts 2 Posters 792 Views 2 Watching
    • O Offline
      oggo
      Hi all,
      while trying to build my first magicmirror I’m struggeling on the usage of MMM-Podcast2.
      I noticed that since MM Release 2.15.0 the package request is removed as it’s deprecated.
      As MMM-Podcast 2 makes use of this package MM is showing this error on startup:
      [11.12.2021 18:18.30.091] [ERROR] Error: Cannot find module 'request'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-Podcast2/node_helper.js
          at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
          at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (internal/modules/cjs/loader.js:732:27)
          at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
          at Module.require (internal/modules/cjs/loader.js:959:19)
          at require (internal/modules/cjs/helpers.js:88:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Podcast2/node_helper.js:11:17)
          at Module._compile (internal/modules/cjs/loader.js:1078:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
      So, my question is: Does anyone maybe already replaced the usage package request with e.g. node-fetch (it’s stated as successor in the release notes) in MMM-Podcast2?
        sdetweil @oggo
        @oggo see this
          sdetweil @oggo
          @oggo until someone changes the code, you can only install request to use this module
          • O oggo referenced this topic on
