    Auto-start not working on Pi Zero W
    9 Posts 3 Posters 1.6k Views 3 Watching
      @sdetweil I test my script on the pi0w (and w2) and have to make a special setup on the pi0w as there is no Electron version for armv6l now…
      so I download a script to use to launch MM as server mode and then launch chromium over that as the UI component
      looks and acts the same
      pi0w needs more memory, so u have to increase the swap space
      as the documented platform is FULL desktop, chromium-browser is installed and usable
        JasperTheWeasel2
        @sdetweil I was having the same problem with mine. I tried the pm2 start and it gave me this error [PM2][ERROR] File ecosystem.config.js not found.
          sdetweil @JasperTheWeasel2
          @jaspertheweasel2 how did u install pm2
            JasperTheWeasel2
            @sdetweil I used your guide on Github. I ran the master script, then the upgrade-script and upgrade-script apply, then screensaveroff, and last fixuppm2.
              @jaspertheweasel2 only one thing to install
              later when new mm release use upgrade
              if u said no to pm2 during install then fixup lets you add it later.
              no need to run them all at once
                JasperTheWeasel2 @sdetweil
                @sdetweil So how can I fix this? Everything else works except it doesn’t automatically start.
                  @jaspertheweasel2 run the fixuppm2 script,
                  happens occasionally don’t know why
