    Auto-start not working on Pi Zero W
    9 Posts 3 Posters 2.0k Views 3 Watching
      Mason 0
      I’ve been troubleshooting many different installers and methods for installer Magic Mirror on the Pi Zero W, and I finally got one to work. However, after booting, the Pi launches the web browser, but I have to manually click the Magic Mirror shortcut in the browser. I used this script for the installation, which includes pm2 auto start. After I found the issue, I disabled the preinstalled pm2 auto-start and made my own based on this guide. Unfortunately, I get the same problem where the pi launches the browser, but not Magic Mirror. To be clear, I can manually start Magic Mirror, but on reboot, only the browser launches. Any ideas? I’m not too experienced working with Raspberry Pi’s, so if you could dumb down the answers that’d be ideal.
        sdetweil @Mason 0
        @mason-0 my setup script configures pm2 to launch installers/mm.sh
        which does npm start
        can u send me the install.log
        same userid at gmail
        pm2 has lots of options
        status
        info
        pm2 --help will show u all the options
        to do start at boot
        you do pm2 start
        and then pm2 save
        to make that restartable at boot
          @sdetweil I test my script on the pi0w (and w2) and have to make a special setup on the pi0w as there is no Electron version for armv6l now…
          so I download a script to use to launch MM as server mode and then launch chromium over that as the UI component
          looks and acts the same
          pi0w needs more memory, so u have to increase the swap space
          as the documented platform is FULL desktop, chromium-browser is installed and usable
            JasperTheWeasel2
            @sdetweil I was having the same problem with mine. I tried the pm2 start and it gave me this error [PM2][ERROR] File ecosystem.config.js not found.
              sdetweil @JasperTheWeasel2
              @jaspertheweasel2 how did u install pm2
                JasperTheWeasel2
                @sdetweil I used your guide on Github. I ran the master script, then the upgrade-script and upgrade-script apply, then screensaveroff, and last fixuppm2.
                  @jaspertheweasel2 only one thing to install
                  later when new mm release use upgrade
                  if u said no to pm2 during install then fixup lets you add it later.
                  no need to run them all at once
                    JasperTheWeasel2 @sdetweil
                    @sdetweil So how can I fix this? Everything else works except it doesn’t automatically start.
                      @jaspertheweasel2 run the fixuppm2 script,
                      happens occasionally don’t know why
