    MMM-SoccerLiveScore
    187 Posts 37 Posters 339.2k Views 35 Watching
    • 0m4r0
      0m4r Module Developer
      @np27np27 I am sorry to hear that :(
      you should try again from the feature/node-fetch .
      if you see any errors, would you please cut&paste them in here so I can have a look at them?
      would you also mind showing me your config for the module?
      https://github.com/0m4r
      N 1 Reply Last reply
      • N
        np27np27 @0m4r
        @0m4r
        Ok ive reinstalled and successfully updated to the feature/fetch-node branch. I think it all installed error free this time!!
        Lets see how things look later today after during the premier league games. I’ll let you know how it goes.
        My config for the module:
        		disabled: false,
        		module: 'MMM-SoccerLiveScore',
        		position: 'top_right',
        		header: 'Live-Scores',
        			leagues: [17],
          			showNames: true,
         			showLogos: true,
         			displayTime: 20 * 1000,
          			showStandings: true,
          			showTables: true,
          			showScorers: false,
        • 0m4r0
          @np27np27
          and can you see something like this in the logs:
          MMM-SoccerLiveScore next request for league "Premier League (17)" on Tue Dec 14 2021 14:34:37 GMT+0100 (Central European Standard Time) for Round 17
          • N
            np27np27 @0m4r
            @0m4r
            Yes the next request date seems to be updating now. So I think its working. Brentford vs ManU is postponed today so it’s a little difficult to gauge if it’s truly working at the moment. Will confirm it later tonight when the rest of the games go live!
            • N
              np27np27
              @0m4r
              It seems to be updating fine now and the api calls all look good and at the right times during live games. Thanks for fixing the module 👍🏾👍🏾
              I do have a bug to report… The module does not handle postponed games well. It does not recognise postponed games, starts these matches as normal and they never end or complete. I see this with the Brentford-ManU game from last night. According to the module the game started and is still playing 😂.
              0m4r0 1 Reply Last reply
              • 0m4r0
                0m4r Module Developer @np27np27
                @np27np27 if you pull once again, I did a quick fix to mark them in orange.
                I will look into the API requests side of the things… but better too many than too few! :D
                • N
                  np27np27 @0m4r
                  @0m4r
                  Hi, yes just updated and noticed the change to orange! Maybe a change to P-P would be better but I guess it all depends on how you have written the code and the api calls. 👍🏾
                  But it all seems to work now, thanks again 😊😊
                  • N
                    np27np27
                    @0m4r looks like the module is still not updating on my system. It seemed to update for a day or two but now has stopped.
                    How does it seem on your mm2?
                    • N
                      np27np27 @np27np27
                      @0m4r ,the api call date changes on the module but the data is stuck and not updating.
                      0m4r0 2 Replies Last reply
                      • 0m4r0
                        @np27np27 I’ll check that :(
                        • 0m4r0
                          @np27np27 I am checking right now the results for “Serie A” and they seem to update…
                          • N
                            np27np27 @0m4r
                            @0m4r
                            Hey, yes just looking at the premier league scores today and it all seems to be updating OK so far. Not sure what was going on last time. Maybe it is OK then?
                            • 0m4r0
                              @np27np27 well, I hope so!
                              Let’s keep an eye on it and see if it really works or if it is just a feeling we have!
                              Thanks for the feedback!
                              • N
                                np27np27 @0m4r
                                Hi @0m4r,
                                It seems to be stuck again for me. I think its happening on the last game on a game week there are multiple days. See screenshot attached taken today on the 28th.
                                • 0m4r0
                                  @np27np27 thanks for the hint - I will be looking into it.
                                  • 0m4r0
                                    @np27np27 I put in a fix, not sure it works 100% :P
                                    I have noticed tho, my approach is not really the best, will need to re-think it and re-implement it. I’d like to reach a point where the API calls are done only if and when needed to reduce network traffic and avoid overloading the API service provider too.
                                    N 2 Replies Last reply
                                    • N
                                      np27np27 @0m4r
                                      @0m4r
                                      OK thanks. Do I update it as you have mentioned before? Or a full reinstall?
                                      • N
                                        np27np27 @0m4r
                                        @0m4r
                                        Also, how do I find new league ID numbers. African nations Cup?
                                        • 0m4r0
                                          @np27np27 you can switch back to the master branch and do a git pull.
                                          It does not look like the Africa nation cup is supported by the APIs :(
                                          • N
                                            np27np27 @0m4r
                                            Hi @0m4r,
                                            Sorry to report but I’m still seeing the same issue. 😔
                                            It’s definitely not updating after the last game of the week starts. Same was seen in this round of premier league games, image attached.
                                            click here for image
                                            • 10
                                            • 9 / 10
