MMM Google Photos error
having troulbe with getting the google photo running
i followed the github instruction but seem to be stuck with the black screen of death
npm start run displays
pi@raspberrypi:~/MagicMirror $ npm start run
magicmirror@2.17.1 start /home/pi/MagicMirror
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “run”[21.12.2021 19:41.00.282] [LOG] Starting MagicMirror: v2.17.1
[21.12.2021 19:41.00.288] [LOG] Loading config …
[21.12.2021 19:41.00.294] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: MagicMirror is not defined
at Object. (/home/pi/MagicMirror/config/config.js:45:12)
at Module._compile (internal/modules/cjs/loader.js:1078:30)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)
at Module.load (internal/modules/cjs/loader.js:935:32)
at Module._load (internal/modules/cjs/loader.js:776:14)
at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
at Module.require (internal/modules/cjs/loader.js:959:19)
at require (internal/modules/cjs/helpers.js:88:18)
at loadConfig (/home/pi/MagicMirror/js/app.js:69:14)
at App.start (/home/pi/MagicMirror/js/app.js:212:3)
[21.12.2021 19:41.00.296] [LOG] Loading module helpers …
[21.12.2021 19:41.00.313] [LOG] Initializing new module helper …
[21.12.2021 19:41.00.314] [LOG] Module helper loaded: updatenotification
[21.12.2021 19:41.00.316] [LOG] No helper found for module: helloworld.
[21.12.2021 19:41.00.317] [LOG] All module helpers loaded.
[21.12.2021 19:41.00.473] [LOG] Starting server on port 8080 …
[21.12.2021 19:41.00.492] [LOG] Server started …
[21.12.2021 19:41.00.494] [LOG] Connecting socket for: updatenotification
[21.12.2021 19:41.00.496] [LOG] Sockets connected & modules started …
[21.12.2021 19:41.00.714] [ERROR] Whoops! There was an uncaught exception…
[21.12.2021 19:41.00.721] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
at Server.setupListenHandle [as _listen2] (net.js:1318:16)
at listenInCluster (net.js:1366:12)
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1503:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:69:8) {
code: ‘EADDRINUSE’,
errno: -98,
syscall: ‘listen’,
address: ‘127.0.0.1’,
port: 8080
[21.12.2021 19:41.00.729] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[21.12.2021 19:41.00.730] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[21.12.2021 19:41.00.770] [LOG] Launching application.
^C[21.12.2021 19:41.23.180] [LOG] Shutting down server…
[21.12.2021 19:41.23.185] [LOG] Stopping module helper: updatenotification -
@sultan-y said in MMM Google Photos error:
how did you install MM?
this means another instance is running…
if pm2 started one, then pm2 status will show you
then pm2 stop xx
where xx is the number or the name on the row of the thing u want to stop
(ps pm2 can run lots of things at once) -
EADDRINUSE got fixed the configurtion error remains
at Module.require (internal/modules/cjs/loader.js:959: -
1.12.2021 23:16.00.533] [ERROR] (node:2556) UnhandledPromiseRejectionWarning: Error: Request failed with status code 403
at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:17:12)
at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:236:11)
at IncomingMessage.emit (events.js:327:22)
at endReadableNT (internal/streams/readable.js:1327:12)
at processTicksAndRejections (internal/process/task_queues.js:80:21)
(Useelectron --trace-warnings ...to show where the warning was created)
[21.12.2021 23:16.00.534] [ERROR] (node:2556) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag--unhandled-rejections=strict(see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
[21.12.2021 23:16.00.535] [ERROR] (node:2556) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.modules: [
module: “MMM-GooglePhotos”,
position: “fullscreen_below”,
albums: [“MagicMirror”], // Set your album name. like [“My wedding”, “family share”, “Travle to Paris”]
updateInterval: 1000 * 60, // minimum 10 seconds.
sort: “new”, // “old”, “random”
uploadAlbum: null, // Only album created bycreate_uploadable_album.js.
condition: {
fromDate: null, // Or “2018-03”, RFC … format available
toDate: null, // Or “2019-12-25”,
minWidth: null, // Or 400
maxWidth: null, // Or 8000
minHeight: null, // Or 400
maxHeight: null, // Or 8000
minWHRatio: null,
maxWHRatio: null,
// WHRatio = Width/Height ratio ( ==1 : Squared Photo, < 1 : Portraited Photo, > 1 : Landscaped Photo)
showWidth: 1080, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
showHeight: 1920,
timeFormat: “YYYY/MM/DD HH:mm”, // Orrelativecan be used.
at createErroryou are getting a permission denied 403 error
from google -
i think i fixed the access but now i get a 503 error
22.12.2021 22:51.16.328] [LOG] /nodehelper/get translation with statuscode-200
[22.12.2021 22:51.16.335] [LOG] /nodehelper/get arabic with statuscode-200
[22.12.2021 22:51.16.338] [LOG] /nodehelper/result-An-Naml:77
[22.12.2021 22:51.16.357] [LOG] 200[object Object]
[22.12.2021 22:51.17.516] [ERROR] (node:4593) UnhandledPromiseRejectionWarning: Error: Request failed with status code 503
[22.12.2021 22:51.17.523] [ERROR] (node:4593) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag--unhandled-rejections=strict(see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
[22.12.2021 22:51.17.526] [ERROR] (node:4593) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. -
apparently i just needed to be patient, it needed to propagate
now its working
howevver the clokc and some other apps have disappeared
is there a way to have it be in the background, so i can see my clock and calendar?
@sultan-y
Which position did you put the module into? set the positionfullscreen_below.
