    Problem with MYCalendar Module
    8 Posts 3 Posters 1.9k Views 3 Watching
      sil3ntstorm
      Hello everyone, since I set up my MM again, my MyCalendar module no longer works, no matter what I do, the screen stays black (you only see a mouse pointer). I copied the data for it from the config.js (which I used earlier). If the MyCalendar module is deactivated, everything goes as normal
      Command npm run config: check says: Your configuration file doesn’t contain syntax errors 🙂 so no error is shown to me here.
      Does anyone else have the problem with the MyCalendar module?
      https://github.com/jclarke0000/MMM-MyCalendar
      • karsten13K Online
        karsten13 @sil3ntstorm
        @sil3ntstorm
          sil3ntstorm
          I don’t understand exactly how to proceed.
          Or are there other modules that show my calendar like this
            sdetweil @sil3ntstorm
            @sil3ntstorm the linked topic shows u how to discover the cause of the black screen and how to fix it
              sil3ntstorm
              It looks like this module is not compatible with MM 2.18. Older versions will work with it, but the latest will no longer work. I have now switched to the standard module
                @sil3ntstorm no. it needs a library which we removed a couple releases ago. the library uses a library that is discontinued (deprecated) due to a security issue
                just follow the instructions in the linked topic and u can fix it.
                  sil3ntstorm
                  solution: But for it to work properly, I still had to run npm install request and npm install valid-url These were removed in the last MagicMirror updates. Now works :thumbs_up:
                    @sil3ntstorm yes
                    u can install multiple things at once if u know
                    npm install x y
