Solved MMM-Hue CORS Policy Issue
found this one https://pratikpc.medium.com/bypassing-cors-with-electron-ab7eaf331605 which could be tested in
js/electron.js
Thanks @karsten13 , seems like it does not work as mentioned below by @Fozi . Seems like the modules uses jQuery and does a call to the bridge to get the data. Seems like I need to log an issue on Github for the module but it has not been touched in the last 3 to 4 years. I will fork it and see if I can make some changes to get it working. The last suggestion you made below seems like code changes module side so I will see what I can do to change it from jQuery to something that would work. Thanks for the replies.
you can test the following, I couldn’t test this completely but the cors error was gone in my tests.
First yo need to create own certs, go into the
config
folder of mm (same folder whereconfig.js
is located) and run this command:openssl req -newkey rsa:4096 \ -x509 \ -sha256 \ -days 3650 \ -nodes \ -out example.crt \ -keyout example.key \ -subj "/C=DE/ST=Hessen/L=Frankfurt/O=MagicMirror/OU=MM/CN=www.example.com"
Then edit your
config.js
and add the following lines under the line withvar config = {
electronOptions: { webPreferences: { webSecurity: false } }, useHttps: true, httpsPrivateKey: "config/example.key", httpsCertificate: "config/example.crt",
(Re)Start mm and test if
MMM-Hue
works now (there will still be a “mixed content” warning). -
@karsten13 Awesome. That worked. Much appreciated for the assist.
@karsten13 You are a genius! That worked for me, too! Thanks so much!
@fozi thanks but … no
would be better to have a solution without
https
, may someone else gets this figured out.As an improvement for the above solution with
https
:Holding the certs in the
config
directory makes them accessible from outside so better move them into a new directory besideconfig
, e.g.certs
which is not exposed. Don’t forget to updateconfig.js
afterwards. -
@karsten13 So I have been tinkering with the MMM-Hue module a bit and have replaced
jQuery
which seems to invokeXMLHttpRequest
, withnode-fetch
, albeit the older version (2.6.1) of node-fetch, but it now returns data without requiring a certificate and the use of https. -
The same problem appears to happen with MMM-Homematic. Getting same errors after update to 2.18.0
Access to XMLHttpRequest at 'http://192.168.178.xx/addons/xmlapi/state.cgi?datapoint_id=1824' from origin 'http://0.0.0.0:8080' has been blocked by CORS policy: The request client is not a secure context and the resource is in more-private address space private.
@karsten13 Its working now with:
var config = { electronOptions: { webPreferences: { webSecurity: false } }, useHttps: true, httpsPrivateKey: "config/example.key", httpsCertificate: "config/example.crt", address: "localhost", port: 8080, // address: '0.0.0.0', ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.178.1/120", "192.168.178.100/24"], language: 'de', modules: [
But with this setting, i have noc access the the RemoteControl-GUI and API also! ;(
I really use it with my homeautomation to show/ hide modules.Is there another possibility?
