    MMM-Hue CORS Policy Issue
    28 Posts 7 Posters 11.0k Views 7 Watching
    • mumblebajM Offline
      mumblebaj Module Developer
      I seem to be having an issue after updating to 2.18 yesterday. MMM-Hue seems not to be working anymore. I get the following error:
      Access to XMLHttpRequest at 'http://bridgeip/api/user/groups' from origin 'http://0.0.0.0:8080' has been blocked by CORS policy: The request client is not a secure context and the resource is in more-private address space `private`.
      Has anybody else had the same issue after updating? There are no errors in the logs. The above error is from the Developer Console.
      karsten13K FoziF 2 Replies Last reply Reply Quote 0
      • karsten13K Online
        karsten13 @mumblebaj
        @mumblebaj
        you can test the following, I couldn’t test this completely but the cors error was gone in my tests.
        First yo need to create own certs, go into the config folder of mm (same folder where config.js is located) and run this command:
        openssl req -newkey rsa:4096 \
                    -x509 \
                    -sha256 \
                    -days 3650 \
                    -nodes \
                    -out example.crt \
                    -keyout example.key \
                    -subj "/C=DE/ST=Hessen/L=Frankfurt/O=MagicMirror/OU=MM/CN=www.example.com"
        Then edit your config.js and add the following lines under the line with var config = {
        	electronOptions: {
        		webPreferences: {
        			webSecurity: false
        	useHttps: true,
        	httpsPrivateKey: "config/example.key",
        	httpsCertificate: "config/example.crt",
        (Re)Start mm and test if MMM-Hue works now (there will still be a “mixed content” warning).
        mumblebajM FoziF 2 Replies Last reply Reply Quote 1
        • karsten13K Online
          @mumblebaj
          This could be caused by the new electron version if you are running this on a raspberry pi.
          If so you could test adding electronOptions in your config.js like:
          let config = {
          	electronOptions: {
                          webPreferences: {
                                  webSecurity: false
          	address: "localhost",
          	port: 8080,
          • FoziF Offline
            Fozi Project Sponsor @mumblebaj
            @mumblebaj I have the same issue with the same error, but with MMM-Homematic since the update to MM 2.18. MM cannot connect to my CCU2 controller to get the device statuses.
            @karsten13 your proposal unfortunately didn’t work :-( But thanks anyway!
            • karsten13K Online
              karsten13 @Fozi
              @fozi I have no test setup so this is difficult without …
              • FoziF Offline
                Fozi Project Sponsor @karsten13
                @karsten13 No worries! I just wanted to let you (and others) know that the config entry does not solve the issue.
                I made a little research around CORS and -at least for me- it doesn’t seem to be trivial to configure electron in a way that specific origins are allowed without disabling the CORS policy completely.
                Anyone around with more knowledge?
                • karsten13K Online
                  karsten13 @Fozi
                  @fozi
                  found this one https://pratikpc.medium.com/bypassing-cors-with-electron-ab7eaf331605 which could be tested in js/electron.js.
                    mumblebaj Module Developer @karsten13
                    Thanks @karsten13 , seems like it does not work as mentioned below by @Fozi . Seems like the modules uses jQuery and does a call to the bridge to get the data. Seems like I need to log an issue on Github for the module but it has not been touched in the last 3 to 4 years. I will fork it and see if I can make some changes to get it working. The last suggestion you made below seems like code changes module side so I will see what I can do to change it from jQuery to something that would work. Thanks for the replies.
                    • karsten13K Online
                      @mumblebaj
                                  -x509 \
                                  -sha256 \
                                  -days 3650 \
                                  -nodes \
                                  -out example.crt \
                      	electronOptions: {
                      		webPreferences: {
                      			webSecurity: false
                      	useHttps: true,
                        @karsten13 Awesome. That worked. Much appreciated for the assist.
                        • FoziF Offline
                          @karsten13 You are a genius! That worked for me, too! Thanks so much!
