    MMM-Hue CORS Policy Issue
    28 Posts 7 Posters 13.8k Views 7 Watching
    • karsten13K
      karsten13 @Fozi
      @fozi I have no test setup so this is difficult without …
      • FoziF
        Fozi Project Sponsor @karsten13
        @karsten13 No worries! I just wanted to let you (and others) know that the config entry does not solve the issue.
        I made a little research around CORS and -at least for me- it doesn’t seem to be trivial to configure electron in a way that specific origins are allowed without disabling the CORS policy completely.
        Anyone around with more knowledge?
        • karsten13K
          karsten13 @Fozi
          @fozi
          found this one https://pratikpc.medium.com/bypassing-cors-with-electron-ab7eaf331605 which could be tested in js/electron.js.
          • mumblebajM
            mumblebaj Module Developer @karsten13
            Thanks @karsten13 , seems like it does not work as mentioned below by @Fozi . Seems like the modules uses jQuery and does a call to the bridge to get the data. Seems like I need to log an issue on Github for the module but it has not been touched in the last 3 to 4 years. I will fork it and see if I can make some changes to get it working. The last suggestion you made below seems like code changes module side so I will see what I can do to change it from jQuery to something that would work. Thanks for the replies.
            • karsten13K
              karsten13 @mumblebaj
              @mumblebaj
              you can test the following, I couldn’t test this completely but the cors error was gone in my tests.
              First yo need to create own certs, go into the config folder of mm (same folder where config.js is located) and run this command:
              openssl req -newkey rsa:4096 \
                          -x509 \
                          -sha256 \
                          -days 3650 \
                          -nodes \
                          -out example.crt \
                          -keyout example.key \
                          -subj "/C=DE/ST=Hessen/L=Frankfurt/O=MagicMirror/OU=MM/CN=www.example.com"
              Then edit your config.js and add the following lines under the line with var config = {
              	electronOptions: {
              		webPreferences: {
              			webSecurity: false
              	useHttps: true,
              	httpsPrivateKey: "config/example.key",
              	httpsCertificate: "config/example.crt",
              (Re)Start mm and test if MMM-Hue works now (there will still be a “mixed content” warning).
              mumblebajM FoziF 2 Replies Last reply Reply Quote 1
              • mumblebajM
                @karsten13 Awesome. That worked. Much appreciated for the assist.
                • FoziF
                  @karsten13 You are a genius! That worked for me, too! Thanks so much!
                  • karsten13K
                    karsten13 @Fozi
                    @fozi thanks but … no
                    would be better to have a solution without https, may someone else gets this figured out.
                    As an improvement for the above solution with https:
                    Holding the certs in the config directory makes them accessible from outside so better move them into a new directory beside config, e.g. certs which is not exposed. Don’t forget to update config.js afterwards.
                    mumblebajM 1 Reply Last reply Reply Quote 1
                    • mumblebajM
                      @karsten13 So I have been tinkering with the MMM-Hue module a bit and have replaced jQuery which seems to invoke XMLHttpRequest, with node-fetch, albeit the older version (2.6.1) of node-fetch, but it now returns data without requiring a certificate and the use of https.
                        CarstenD
                        The same problem appears to happen with MMM-Homematic. Getting same errors after update to 2.18.0
                        Access to XMLHttpRequest at 'http://192.168.178.xx/addons/xmlapi/state.cgi?datapoint_id=1824' from origin 'http://0.0.0.0:8080' has been blocked by CORS policy: The request client is not a secure context and the resource is in more-private address space private.
                        • karsten13K
                          karsten13 @CarstenD
                          @carstend
                          yes, was already reporty by @Fozi some posts above, MMM-Homematic uses jquery too.
                          • O
                            OberfragGER @karsten13
                            @karsten13 Its working now with:
                            var config =
                              electronOptions: {
                            		webPreferences: {
                            			webSecurity: false
                              useHttps: true,
                              address: "localhost",
                              port: 8080,
                            //  address: '0.0.0.0',
                              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.178.1/120", "192.168.178.100/24"],
                              language: 'de',
                            But with this setting, i have noc access the the RemoteControl-GUI and API also! ;(
                            I really use it with my homeautomation to show/ hide modules.
                            Is there another possibility?
                            • karsten13K
                              karsten13 @OberfragGER
                              @oberfragger
                              you must access the site with https, e.g. https://192.168.0.143:8080/remote.html
                                CarstenD
                                There is now a new version available for MMM-Homematic that also works w/o changing the config.
                                spitzlbergerjS 1 Reply Last reply Reply Quote 0
                                • FoziF
                                  @carstend Yeah, was just noted, too, about the update.
                                  Some how I ran ino a problem when applying ‘git pull’, so I had to reinstall the module.
                                  First the screen remained black. so I hat to install manually the ‘request’ library manually (see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later). Now it works!
                                  • mumblebajM
                                    mumblebaj Module Developer @mumblebaj
                                    @mumblebaj This is the new module I created. Does not require https.
                                    https://github.com/mumblebaj/MMM-PhilipsHue.git
                                    I am sure this will need to be changes once they enforce the headers stuff but for now it will work just fine.
                                    • O
                                      @karsten13 said in MMM-Hue CORS Policy Issue:
                                      @oberfragger
                                      Unfortunatly its not working via https. Still connection refused. I dint think that https://github.com/CatoAntonsen/MMM-MotionEye will update after 5 years.
                                      • karsten13K
                                        @oberfragger
                                        can you access the mirror with https://<ip-of-pi>:8080?
                                        May you are using a client which is not in the ipWhitelist? You can test this with setting ipWhitelist: [], in your config.js.
                                        • O
                                          https://:8080
                                          No. Thats excactly what im telling you:
                                          When
                                          then i dont have any access to https://ip-of-pi:8080 or http://ip-of-pi:8080.
                                          When
                                          address: '0.0.0.0',
                                          i have no problem to access Remote-Control-Gui/ Webpage. The ipWhitelist is aready set.
                                            sdetweil @OberfragGER
                                            @oberfragger correct… localhost means ONLY apps INSIDE the same machine can connect.
                                            so you could open a browser ON THE PI screen and connect, but not from another device
                                            0.0.0.0 means listen for incoming connections on all network interfaces
                                            (Ethernet and wifi at once, on pi4 if both enabled)
