Solved v2.18.0 update gave black screen, then nothing.
pi@magicmirror:~/MagicMirror $ pm2 stop 0 [PM2] Applying action stopProcessId on app [0](ids: [ '0' ]) [PM2] [MagicMirror](0) ✓ ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 0 │ stopped │ 0% │ 0b │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ pi@magicmirror:~/MagicMirror $ pm2 flush [PM2] Flushing /home/pi/.pm2/pm2.log [PM2] Flushing: [PM2] /home/pi/.pm2/logs/MagicMirror-out.log [PM2] /home/pi/.pm2/logs/MagicMirror-error.log [PM2] Logs flushed pi@magicmirror:~/MagicMirror $ pm2 start 0 [PM2] Applying action restartProcessId on app [0](ids: [ '0' ]) [PM2] [MagicMirror](0) ✓ [PM2] Process successfully started ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.4mb │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50 [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 50 lines: PM2 | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines: 0|MagicMir | 0|MagicMir | > magicmirror@2.18.0 start 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines: 0|MagicMir | App threw an error during load 0|MagicMir | TypeError: Log.log is not a function 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) 0|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32) 0|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12) 0|MagicMir | at Function.c._load (node:electron/js2c/asar_bundle:5:13331) 0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19) 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead. 0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created) 0|MagicMir | A JavaScript error occurred in the main process 0|MagicMir | Uncaught Exception: 0|MagicMir | TypeError: Log.log is not a function 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) 0|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32) 0|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12) 0|MagicMir | at Function.c._load (node:electron/js2c/asar_bundle:5:13331) 0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19) 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization 0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
@richard238 ok, do
cd ~/MagicMirror rm -rf node_modules rm package-lock.json npm install --only=prod
pi@magicmirror:~/MagicMirror $ rm -rf node_modules pi@magicmirror:~/MagicMirror $ rm package-lock.json pi@magicmirror:~/MagicMirror $ npm install --only=prod > magicmirror@2.18.0 install > echo "Installing vendor files ... > " && cd vendor && npm install --loglevel=error Installing vendor files ... up to date, audited 10 packages in 4s found 0 vulnerabilities > magicmirror@2.18.0 postinstall > npm run install-fonts && echo "MagicMirror installation finished successfully! > " > magicmirror@2.18.0 install-fonts > echo "Installing fonts ... > " && cd fonts && npm install --loglevel=error Installing fonts ... up to date, audited 2 packages in 13s found 0 vulnerabilities MagicMirror installation finished successfully! > magicmirror@2.18.0 prepare > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed. no husky installed. added 267 packages, and audited 268 packages in 6m 19 packages are looking for funding run `npm fund` for details found 0 vulnerabilities pi@magicmirror:~/MagicMirror $
@richard238 and try to run mm again
Online, but no MM showing.
pi@magicmirror:~/MagicMirror $ pm2 start MagicMirror [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ]) [PM2] [MagicMirror](0) ✓ [PM2] Process successfully started ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.5mb │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ pi@magicmirror:~/MagicMirror $
@richard238 and show log output again?
and output of
node -v
npm -v -
pi@magicmirror:~/MagicMirror $ pm2 logs --lines=50 [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 50 lines: PM2 | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2022-01-06T14:24:56: PM2 log: App [MagicMirror:0] online PM2 | 2022-01-06T14:50:49: PM2 log: Stopping app:MagicMirror id:0 PM2 | 2022-01-06T14:50:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT] PM2 | 2022-01-06T14:50:49: PM2 log: pid=12707 msg=process killed PM2 | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] starting in -fork mode- PM2 | 2022-01-06T14:50:59: PM2 log: App [MagicMirror:0] online /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines: 0|MagicMir | 0|MagicMir | > magicmirror@2.18.0 start 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | 0|MagicMir | 0|MagicMir | > magicmirror@2.18.0 start 0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js 0|MagicMir | /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines: 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | (node:12755) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead. 0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created) 0|MagicMir | A JavaScript error occurred in the main process 0|MagicMir | Uncaught Exception: 0|MagicMir | TypeError: Log.log is not a function 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) 0|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32) 0|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12) 0|MagicMir | at Function.c._load (node:electron/js2c/asar_bundle:5:13331) 0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19) 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | [12789:0106/142502.942799:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization 0|MagicMir | [12805:0106/142503.366582:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process. 0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT 0|MagicMir | App threw an error during load 0|MagicMir | TypeError: Log.log is not a function 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) 0|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32) 0|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12) 0|MagicMir | at Function.c._load (node:electron/js2c/asar_bundle:5:13331) 0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19) 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | (node:18699) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead. 0|MagicMir | (Use `electron --trace-deprecation ...` to show where the warning was created) 0|MagicMir | A JavaScript error occurred in the main process 0|MagicMir | Uncaught Exception: 0|MagicMir | TypeError: Log.log is not a function 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:20:5) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) 0|MagicMir | at Module.load (node:internal/modules/cjs/loader:988:32) 0|MagicMir | at Module._load (node:internal/modules/cjs/loader:829:12) 0|MagicMir | at Function.c._load (node:electron/js2c/asar_bundle:5:13331) 0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1012:19) 0|MagicMir | at require (node:internal/modules/cjs/helpers:94:18) 0|MagicMir | at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:4:14) 0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1116:14) 0|MagicMir | [18754:0106/145107.193182:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization 0|MagicMir | [18773:0106/145107.559447:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
pi@magicmirror:~/MagicMirror $ node -v v17.3.0 pi@magicmirror:~/MagicMirror $ npm -v 8.3.0
@richard238 can u show the ~/MagicMirror/config/config.js
config.js, minus private data.
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. */ var config = { port: 8080, address:"0.0.0.0", ipWhitelist: [], //ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",], language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', }, { module: "updatenotification", position: "top_bar" }, { module: 'clock', position: 'top_left' }, { module: 'calendar', header: 'Calendar', position: 'top_left', config: { maximumEntries: 6, // Total Maximum Entries maximumNumberOfDays: 365, displaySymbol: true, defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/ displayRepeatingCountTitle: false, defaultRepeatingCountTitle: "", maxTitleLength: 30, fetchInterval: 5 * 60 * 1000, // Update every 5 minutes. animationSpeed: 2000, fade: true, showEnd: false, urgency: 0, timeFormat: "absolute", dateFormat: "ddd Do MMMM", getRelative: 0, fadePoint: 0.50, // Start on 1/4th of the list. hidePrivate: false, calendars: [ { symbol: 'calendar-check-o ', url: 'https:/nnnnnnnnnnnnnnnnnnnnn/basic.ics' } ], } }, { module: 'calendar', header: 'Binday', position: 'bottom_left', config: { maximumEntries: 4, // Total Maximum Entries maximumNumberOfDays: 365, displaySymbol: true, defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/ displayRepeatingCountTitle: false, defaultRepeatingCountTitle: "", maxTitleLength: 30, fetchInterval: 5 * 60 * 1000, // Update every 5 minutes. animationSpeed: 2000, fade: true, showEnd: false, urgency: 0, timeFormat: "absolute", dateFormat: "ddd Do MMMM", getRelative: 0, fadePoint: 0.50, // Start on 1/4th of the list. hidePrivate: false, calendars: [ { symbol: 'trash-o ', url: 'https:/nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn/basic.ics' } ], titleReplace: { // "'s birthday": "", // "Recycling": "Bins", "Red Bin": "Red & Black Bins", "Green Bin": "Green & Black Bins" }, // Override start method. start: function () { Log.log("Starting module: " + this.name); /* This code changed times to 24hr clock until April 17 system update. ** Set locale. ** if (config.language === 'en' && config.timeFormat == 24) { ** config.language = 'en-gb'; ** } ** moment.locale(config.language); */ for (var c in this.config.calendars) { var calendar = this.config.calendars[c]; calendar.url = calendar.url.replace("webcal://", "http://"); this.addCalendar(calendar.url, calendar.user, calendar.pass); } this.calendarData = {}; this.loaded = false; }, } }, { module: 'compliments', position: 'lower_third', config: { anytime: [ "A1", "A2", "A3" ], morning: [ "M1", "M2", "M3" ], afternoon: [ "N1", "N2", "N3" ], evening: [ "E1", "E2", "E3" ] }, updateInterval: 30000, remoteFile: null, fadeSpeed: 4000 /*config: { remoteFile: 'compliments.json' }*/ }, { module: 'MMM-doomsDay', position: 'top_center', // This can be any of the regions, best results in center regions config: { doomsDay: "2022-01-06 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date /* doomsDay: "2020-12-21 24:00:00", // YYYY-MM-DD HH:MM:SS, Do not alter the time, just the date */ toWhat: "today", // See 'Configuration options' for more information. } }, { module: 'currentweather', header: 'Current weather for: ', position: 'top_right', config: { location: 'nnnnnnnnnnnnnnnn,GB', locationID: 'nnnn', //ID from http://www.openweathermap.org appid: 'nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn' } }, { module: 'weatherforecast', position: 'top_right', header: 'Weather Forecast', config: { location: 'nnnnnn,GB', locationID: 'nnnnnnn', //ID from http://www.openweathermap.org appid: 'aaannnnnnnnnn' } }, { module: 'MMM-MysqlQuery', position: 'bottom_right', header: 'Greenhouse Status', config: { connection: { host: "192.168.1.23", port: 3306, user: "nnnnnnnnnnnnnnnn", password: "nnnnnnnnnnnnnnnn", database: "garage" }, /* query: `select Temp-2 from readings order by ID desc limit 1`, */ query: "select Added, \ Temp, \ Pressure, \ Humidity \ from gh_readings \ order by ID \ desc limit 3", intervalSeconds: 1 * 60, emptyMessage: "No data!", columns: [ { name: "Added", title: "At", cssClass: "left", dateFormat: "time", dateLocale: "en-GB" }, { name: "Temp", title: "Temp", cssClass: "left", suffix: "°C", nullValue: "???" }, { name: "Pressure", title: "Pressure", cssClass: "left", suffix: " hPa", nullValue: "???" }, { name: "Humidity", title: "Humidity", cssClass: "left", suffix: " %" }, ] } }, */ { module: 'newsfeed', position: 'bottom_bar', config: { feeds: [ { title: "BBC World", url: "http://feeds.bbci.co.uk/news/world/rss.xml" }, { title: "Al Jazeera", url: "https://www.aljazeera.com/xml/rss/all.xml" }, { title: "Sky news", url: "http://feeds.skynews.com/feeds/rss/world.xml" } ], showSourceTitle: true, showPublishDate: true, reloadInterval: 2 * 60 * 1000, // every 5 minutes updateInterval: 2 * 5000 } } ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}
@richard238 said in v2.18.0 update gave black screen, then nothing.:
> // Override start method. > start: function () { > Log.log("Starting module: " + this.name); > > /* This code changed times to 24hr clock until April 17 system update. > ** Set locale. > ** if (config.language === 'en' && config.timeFormat == 24) { > ** config.language = 'en-gb'; > ** } > ** moment.locale(config.language); > */ > > > for (var c in this.config.calendars) { > var calendar = this.config.calendars[c]; > calendar.url = calendar.url.replace("webcal://", "http://"); > this.addCalendar(calendar.url, calendar.user, calendar.pass); > } > > this.calendarData = {}; > this.loaded = false; > },
what is that? I’m not aware of any code in config for calendar
for grins, can you add // in front of the Log.log statement
