    Black Screen with some modules + linux-armv Error
    14 Posts 3 Posters 5.7k Views 3 Watching
      JohnGalt
      New install, using Sam D’s install script on buster: It runs OK with default modules as well as MMM-Worldclock [the MM displays on the local monitor, as well as from another machine using the browser]. When I enable either MMM-BackgroundSlideshow or MMM-DynamicWeather I get both a black screen on the local display as well as the web server stops as evidenced by being unable to connect in a browser from another machine. The first thing that catches my eye in the logs is an error that the linux-armv7 binaries cannot be used on the linux-armdefault platform. I am running on a Raspberry Pi 4. Any ideas of what went wrong?
      Logs output:
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/index.js:3:15)
      0|MagicMir | [03.01.2022 18:15.55.981] [ERROR] Whoops! There was an uncaught exception...
      0|MagicMir | [03.01.2022 18:15.55.985] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
      0|MagicMir |     at Object.hasVendoredLibvips (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/libvips.js:82:13)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/constructor.js:7:22)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
      0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
      0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:988:32)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:829:12)
      0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
      0|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
      0|MagicMir | [03.01.2022 18:15.55.986] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [03.01.2022 18:15.55.987] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
      0|MagicMir | [03.01.2022 18:15.55.860] [LOG]   No helper found for module: MMM-Worldclock.
      0|MagicMir | [03.01.2022 18:15.55.862] [LOG]   No helper found for module: MMM-DynamicWeather.
      0|MagicMir | [03.01.2022 18:15.55.960] [LOG]   Loading module helpers ...
      0|MagicMir | [03.01.2022 18:15.55.962] [LOG]   No helper found for module: alert.
      0|MagicMir | [03.01.2022 18:15.55.963] [LOG]   Initializing new module helper ...
      0|MagicMir | [03.01.2022 18:15.55.964] [LOG]   Module helper loaded: updatenotification
      0|MagicMir | [03.01.2022 18:15.55.965] [LOG]   No helper found for module: clock.
      0|MagicMir | [03.01.2022 18:15.55.966] [LOG]   Initializing new module helper ...
      0|MagicMir | [03.01.2022 18:15.55.966] [LOG]   Module helper loaded: calendar
      0|MagicMir | [03.01.2022 18:15.55.968] [LOG]   No helper found for module: weather.
      0|MagicMir | [03.01.2022 18:15.55.968] [LOG]   Initializing new module helper ...
      0|MagicMir | [03.01.2022 18:15.55.969] [LOG]   Module helper loaded: newsfeed
      0|MagicMir | [03.01.2022 18:15.55.970] [LOG]   No helper found for module: MMM-Worldclock.
      0|MagicMir | [03.01.2022 18:15.55.972] [LOG]   No helper found for module: MMM-DynamicWeather.
      0|MagicMir | [03.01.2022 18:15.57.473] [LOG]   Launching application.
        sdetweil @JohnGalt
        @johngalt said in Black Screen with some modules + linux-armv Error:
        yes, this module uses a library,
        which has a problem now on 32bit systems…
        is reported in the module github… no fix found yet
          JohnGalt
          Sam - thanks. Do you happen to know whether this is also true for MMM-DynamicWeather?
            sdetweil @JohnGalt
            @johngalt looking at the code and package.json
            its this
              JohnGalt
              @sdetweil - thanks. I may just disable the two offending modules for now, and then dig thru that post.
              BKeyportB 1 Reply Last reply
              • BKeyportB
                BKeyport Module Developer @JohnGalt
                @johngalt Disable Background slideshow, then dig through the post - dynamic weather will work after you do the steps in the post.
                J 1 Reply Last reply
                  JohnGalt
                  @ BKeyport - thanks. I’ve disabled that module and found one that works. I will work on the MMM-DynamicWeather, hopefully today. Thanks to you and Sam for the support!
                  • BKeyportB
                    @johngalt What did you end up using for the background? I’m in the same boat.
                      sdetweil @BKeyport
                      @bkeyport I use MMM-ImagesPhotos, I added some stuff to retain the image aspect ratio, not cover or contain which both distort the image… then added support for color or blur fill outside the image…
                      loads from a folder in the module folder (altho that can be a link to wherever, I link it to my file server)
                      https://github.com/sdetweil/MMM-ImagesPhotos
                      my uploadPics module will take images from your qr connected device and put them in whatever image storage location u like (it defaults to the ImagesPhotos location (‘uploads’)
                      https://github.com/sdetweil/uploadPics
                        JohnGalt
                        I am trying MMM-SimpleBGSlideshow, but may try the one Sam is using. I do have this one up an running, but it appears to have limited functionality.
                          sdetweil @JohnGalt
                          what function are u looking for?
                            JohnGalt @sdetweil
                            @sdetweil - the documentation indicates ‘It does not do recursive search of image folders’, which I would prefer. The author also indicates he cut out features from the module he forked, but didn’t specify what features. As I said, time will tell whether I stick with it, or give another a try.
                              sdetweil @JohnGalt
                              @johngalt ok. this one also does not recurse.
                              it could be added of course
                                JohnGalt @BKeyport
                                @bkeyport and Sam: thanks for the inputs. I went through my logs and the referenced thread, and now do have DynamicWeather working. Much appreciated!
