    Problems with bring app Module
    11 Posts 4 Posters 3.6k Views 4 Watching
      Jagsi
      Since a few weeks or months I have problems with my bring module - since a few days I try now to solve it unfortunately I am not able to
      I hope someone can help me with that.
      The MM is not showing nothing. Later I will post a screenshot of the logs.
      Error: Unexpected Error during download of the catalog Error: connect ETIMEOUT
        Jagsi
        here is the screenshot of the logs
        please help
          sdetweil @Jagsi
          @jagsi sounds like the server the module is trying to connect to is down. (timeout)
          what module is that?
            Jagsi @sdetweil
            @sdetweil said in Problems with bring app Module:
            thats the Bring Module" nobody else has this issue?
              sdetweil @Jagsi
              @jagsi said in Problems with bring app Module:
              Bring Module
              what is the name of the module,? there are multiple with ‘bring’ in their names
                Jagsi @sdetweil
                its called “Bring List”
                  sdetweil @Jagsi
                  “Bring List”
                  well, technically its called
                  MMM-bringList
                  and is located here
                  https://github.com/rseidt/MMM-bringList
                  as the author updated something a couple months ago, I would suggest you open an issue there to engage him in the problem.
                    Jagsi @sdetweil
                    @sdetweil hmm ok I will try - maybe you know an other module for Bring?
                    S FoziF 2 Replies Last reply Reply Quote 0
                      sdetweil @Jagsi
                      @jagsi I do not… as moderator I generally try to help with install and setup issues… try to ctach any recurring problems,
                      but don’t get into individual modules much… too many to know what they do , how best to use them , etc.
                      • FoziF Offline
                        Fozi Project Sponsor @Jagsi
                        @jagsi I use MMM-Bring https://github.com/werthdavid/MMM-Bring
                        Have no problems with it
                          BigTJ
                          I’ve been using this app and module for a few months. When it works it’s great. There was an issue a few weeks ago when the HTTPS connections no longer worked due to problem with a verifying site. This was resolved by another Bring user to use HHTP connections instead and has worked until the last few weeks. Now the module does not work at all although the app still works well. Apparently the app does not have an official API and the owners have changed the way the app and data works together. I do not have sufficient knowledge of node.js to begin to resolve this issue and have therefore resorted to using the google sheets module as a reminder list. it’s not as easy to use but it is reliable and uses the google official API.
                          Hope this is informative and possibly helpful.
