    MMM-DailyPokemon Issue
    modules won’t loadconfig.jshelp
    13 Posts 3 Posters 4.7k Views 3 Watching
    • mumblebajM
      mumblebaj Module Developer @millis
      @millis said in MMM-DailyPokemon Issue:
      [14.01.2022 16:55.01.943] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:111
      var config = {
      Ok. Post the content of config.js. Once you have pasted the code here, select it all and click the code (</>) button.
      M 1 Reply Last reply
        millis @mumblebaj
        @mumblebaj
        I did wonder how everyone was doing that!
        The only thing I have done is just removed my API Key and location from the weather app as ive seen on here its just good practice to do so?
        Again Thank you for looking into this for me.
        /* Magic Mirror Config Sample
         * By Michael Teeuw https://michaelteeuw.nl
         * MIT Licensed.
         * see https://docs.magicmirror.builders/getting-started/configuration.html#general
         * and https://docs.magicmirror.builders/modules/configuration.html
        let config = {
        	address: "localhost", 	// Address to listen on, can be:
        	port: 8080,
        	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
        	language: "en",
        	locale: "en-US",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check",
        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
        			module: "compliments",
        			position: "lower_third"
        			module: "weather",
        				type: "current",
        				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				apiKey: ""
        			module: "weather",
        			header: "Weather Forecast",
        				type: "forecast",
        				apiKey: ""
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "Sky News",
        						url: "https://feeds.skynews.com/feeds/rss/uk.xml"
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: true,
        				broadcastNewsUpdates: true
        var config = {
                    module: "MMM-DailyPokemon",
                    position: "top_center",
                        updateInterval: 600000,
                        minPoke: 4,
                        maxPoke: 151,
                        grayscale: true,
                        showType: true,
                        language: "en",
                        genera: true,
                        gbaMode: true,
                        nameSize: 26,
                        flavorText: false
        I have no clue about anything until i try
        mumblebajM 1 Reply Last reply
        • mumblebajM
          var config = {
          module: “MMM-DailyPokemon”,
          position: “top_center”,
          minPoke: 4,
          maxPoke: 151,
          grayscale: true,
          showType: true,
          language: “en”,
          genera: true,
          gbaMode: true,
          nameSize: 26,
          flavorText: false
          This is your problem. Everything between the square brackets need to be within the previous modules collection i.e. between the previous square brackets “[ ]”.
            millis @mumblebaj
            @mumblebaj
            Thank you for looking over my code for me, I really do appreciate it, as i said before I am new to all of this and its just a big mystery to me (for the moment)
            so what would I need to change in my code to fix this?
            from your reply am I right in saying the issue lies with the placement of the square brackets?
            I have tried removing them and that didn’t work and I also moved the code into the module above (inside those square brackets)
            This is the link from where i got the code it was literally a case of following the install instructions followed by a quick copy and paste
            https://github.com/NolanKingdon/MMM-DailyPokemon
            Sorry for being an absolute pain, I really do appreciate you taking up your own time to try and help me!
            Ashley.
            mumblebajM M 2 Replies Last reply
            • mumblebajM
              @millis You only need this piece of the module config code:
                              minPoke: 4,
                              maxPoke: 151,
                              grayscale: true,
                              showType: true,
                              language: "en",
                              genera: true,
                              gbaMode: true,
                              nameSize: 26,
                              flavorText: false
              This needs to go into the module block. You can paste it between the alert and clock modules.
              			module: "alert",
              			position: "top_bar"
                              minPoke: 4,
                              maxPoke: 151,
                              grayscale: true,
                              showType: true,
                              language: "en",
                              genera: true,
                              gbaMode: true,
                              nameSize: 26,
                              flavorText: false
              			module: "clock",
              Then remove the incorrect code you pasted at the bottom of the file.
                mickecarlsson @millis
                The previous poster solved it, and I made one mistake in my post.
                You also need to change let config= to var config=
                in the beginning of the config.js
                  millis @mumblebaj
                  @mumblebaj
                  YES!!!
                  Thank you so much!! it works!!!
                  out of interest then how come it gets placed in between the alert and clock and not at the bottom of the code? is it due the position placement on the mirror?
                  Again Thank you so much!!
                  Ashley.
                  • mumblebajM
                    @millis You can place it anywhere in the module [ ] block, not outside it like you have done.
                      millis @mumblebaj
                      @mumblebaj
                      Okay that is awesome! thank you for that and everything else!
                      now i can try and add more modules as that one the first one i tried!
                      Honestly, Thank you!
                      • mumblebajM
                        @millis No problem. Just mark the post as solved.
