    Automatic Updates
    9 Posts 4 Posters 1.7k Views 5 Watching
    • Cliff365C Offline
      Cliff365
      I’m running MagicMirror using pm2 if that matters. What I am looking for, if it’s possible, is some way to update MagicMirror and modules on startup. Is such a thing possible, or even desirable?
        sdetweil @Cliff365
        @cliff365 there is no auto update that I am aware of, and based on the changes in the last few releases I would not want this.
        lots of work has gone into building a system that does what you want…
        I personally would not be excited to have it crash after an update…
        thats why my upgrade script is a two pass approach… test on first pass, identify any issues that need to be resolved,
        make changes on second pass
        pi0w got whacked this release, as we need a new node level, but its not available on pi0w…(easily)
        and then electron is not available, so I have been setting you chromium over server mode…
        now chromium (and firefox) are permanently busted on pi0w… have to install a downlevel chromium to get something to work
        some of the network security stuff is impacts, cross origin restrictions (CORS) are affecting modules now…
        some that are used frequently but haven’t been maintained…
        MM ships a new release every 90 days… thats a LOT of churn (aka work) you may not need or want
        Cliff365C 1 Reply Last reply Reply Quote 0
        • Cliff365C Offline
          Cliff365 @sdetweil
          @sdetweil Thanks for the quick reply. I use your upgrade script and it is nothing short of amazing. I’ll take your advice and do updates with the script.
          The problem I constantly battle is pm2 is just a little aggressive on restarting MM, and it takes me many tries to finally do a ‘pm2 stop all’ so I can have a command line. I wish I knew how to increase the time for pm2 restarts.
          S bugsounetB 3 Replies Last reply Reply Quote 0
            sdetweil @Cliff365
            @cliff365 just minimize the screen
            alt-spacebar, n
            and open a terminal window
            ctrl-alt-t
            or use ssh, from your pc or phone, so you don’t need to do that
              sdetweil @Cliff365
              @cliff365 pm2’s JOB is to restart the apps it manages…
              • Cliff365C Offline
                Cliff365 @sdetweil
                @sdetweil I did not know that was possible. Another thanks!
                  sdetweil @Cliff365
                  @cliff365 magicmirror is just a full screen app, running in a normal browser
                  • bugsounetB Offline
                    bugsounet Banned @Cliff365
                    @cliff365 I have done a. Module for this ;)
                    CFennerC 1 Reply Last reply Reply Quote 0
                    • CFennerC Offline
                      CFenner @bugsounet
                      @bugsounet said in Automatic Updates:
                      Would be nice to have repository specific auto update functionality in the default module.
