    updateDom() blocks MagicMirror
    28 Posts 2 Posters 8.9k Views 2 Watching
    • 1 Offline
      1BlauNitrox @sdetweil
      @sdetweil Do you remember my problem yesteray that my magic mirror doesn`t start? I started the program today in the morning. Without doing anythink since yesterday evening, the same error occurs.
      The only think I change was that I renamed lenght to length. Than I deleted the module module and copyed the new one.
      old post: https://forum.magicmirror.builders/topic/16233/error-while-starting-magic-mirror/29
        sdetweil @1BlauNitrox
        @1blaunitrox I need to see the messages output by npm start
        if you use pm2, then pm2 logs --lines=50
        also maybe info from the developers window, ctrl-shift-i on the keyboard and select the console tab and scroll up to see any errors red text
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          Here is the .pm2/logs/MagicMirror-error.log
          https://haste.lyrotopia.net/equzexapal.js
          Its always the same error
          Here is the .pm2/logs/MagicMirror-out.log
          https://haste.lyrotopia.net/mosubanoro.css
            @1blaunitrox ok, weird…
            npm -v
            node -v
            which user is pm2 installed on?
            pm2 info 0
            • 1 Offline
                @1blaunitrox ok, do this
                pm2 stop all
                pm2 delete 0
                pm2 save
                the run my fixuppm2.sh script from here
                • 1 Offline
                  @sdetweil I installed the software again. Now it works, but I think I will see this error soon again.
                  btw: I wrote an issues on git: https://github.com/MichMich/MagicMirror/issues/2793
                    @1blaunitrox i saw the git issue
                    can u do pm2 info MagicMirror
                    again
                    • 1 Offline
                      @sdetweil I installed the software like in the docs show. So I haven`t installed pm2
                        @1blaunitrox said in updateDom() blocks MagicMirror:
                        the fixuppm2 installs it if needed
                        but u had it installed cause you used it to launch MM…
                          my script fixes little odds and ends not covered by the doc
