    updateDom() blocks MagicMirror
    28 Posts 2 Posters 9.8k Views 2 Watching
      @sdetweil JSON.parse, JSON. stringify
      u have an object so, stringify turns it into text
      parse takes text and makes an object
      • 1 Offline
        1BlauNitrox @sdetweil
        @sdetweil What about JSON.stringify(this.response);
          sdetweil @1BlauNitrox
          @1blaunitrox that would work
          but it will be the JSON text representation of the object
          all fields and values
          1 1 Reply Last reply Reply Quote 0
          • 1 Offline
            First: Is there an other option?
            Second: I added the getData() function in getDom()
                    const wrapper = document.createElement("div");
                    this.getData();
                    if(this.response.lenght <= 0) {
                        wrapper.innerHTML = "No Entries";
                    } else {
                        wrapper.innerHTML = JSON.stringify(this.response);
                    return wrapper;
            Now the mirror show UNDEFINED again
              @1blaunitrox length
              spelling matters…
              use the debugger
                @1blaunitrox this.getData() is not synchronous, so it will return long before the data is ready
                don’t call from getDom()
                  see the doc
                  https://docs.magicmirror.builders/development/introduction.html#module-structure
                  https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
                  notificationReceived in particular
                  • 1 Offline
                    @sdetweil Do you remember my problem yesteray that my magic mirror doesn`t start? I started the program today in the morning. Without doing anythink since yesterday evening, the same error occurs.
                    The only think I change was that I renamed lenght to length. Than I deleted the module module and copyed the new one.
                    old post: https://forum.magicmirror.builders/topic/16233/error-while-starting-magic-mirror/29
                      @1blaunitrox I need to see the messages output by npm start
                      if you use pm2, then pm2 logs --lines=50
                      also maybe info from the developers window, ctrl-shift-i on the keyboard and select the console tab and scroll up to see any errors red text
                      • 1 Offline
                        Here is the .pm2/logs/MagicMirror-error.log
                        https://haste.lyrotopia.net/equzexapal.js
                        Its always the same error
                        Here is the .pm2/logs/MagicMirror-out.log
                        https://haste.lyrotopia.net/mosubanoro.css
                          @1blaunitrox ok, weird…
                          npm -v
                          node -v
                          which user is pm2 installed on?
                          pm2 info 0
                          • 1 Offline
                              @1blaunitrox ok, do this
                              pm2 stop all
                              pm2 delete 0
                              pm2 save
                              the run my fixuppm2.sh script from here
                              • 1 Offline
                                @sdetweil I installed the software again. Now it works, but I think I will see this error soon again.
                                btw: I wrote an issues on git: https://github.com/MichMich/MagicMirror/issues/2793
                                  @1blaunitrox i saw the git issue
                                  can u do pm2 info MagicMirror
                                  again
                                  • 1 Offline
                                    @sdetweil I installed the software like in the docs show. So I haven`t installed pm2
                                      @1blaunitrox said in updateDom() blocks MagicMirror:
                                      the fixuppm2 installs it if needed
                                      but u had it installed cause you used it to launch MM…
                                        my script fixes little odds and ends not covered by the doc
