    updateDom() blocks MagicMirror
    28 Posts 2 Posters 9.5k Views 2 Watching
      sdetweil @1BlauNitrox
      @1blaunitrox length
      spelling matters…
      use the debugger
        @1blaunitrox this.getData() is not synchronous, so it will return long before the data is ready
        don’t call from getDom()
          see the doc
          https://docs.magicmirror.builders/development/introduction.html#module-structure
          https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
          notificationReceived in particular
          1 1 Reply Last reply Reply Quote 0
          • 1 Offline
            1BlauNitrox @sdetweil
            @sdetweil Do you remember my problem yesteray that my magic mirror doesn`t start? I started the program today in the morning. Without doing anythink since yesterday evening, the same error occurs.
            The only think I change was that I renamed lenght to length. Than I deleted the module module and copyed the new one.
            old post: https://forum.magicmirror.builders/topic/16233/error-while-starting-magic-mirror/29
              @1blaunitrox I need to see the messages output by npm start
              if you use pm2, then pm2 logs --lines=50
              also maybe info from the developers window, ctrl-shift-i on the keyboard and select the console tab and scroll up to see any errors red text
              • 1 Offline
                Here is the .pm2/logs/MagicMirror-error.log
                https://haste.lyrotopia.net/equzexapal.js
                Its always the same error
                Here is the .pm2/logs/MagicMirror-out.log
                https://haste.lyrotopia.net/mosubanoro.css
                  @1blaunitrox ok, weird…
                  npm -v
                  node -v
                  which user is pm2 installed on?
                  pm2 info 0
                  • 1 Offline
                      @1blaunitrox ok, do this
                      pm2 stop all
                      pm2 delete 0
                      pm2 save
                      the run my fixuppm2.sh script from here
                      • 1 Offline
                        @sdetweil I installed the software again. Now it works, but I think I will see this error soon again.
                        btw: I wrote an issues on git: https://github.com/MichMich/MagicMirror/issues/2793
                          @1blaunitrox i saw the git issue
                          can u do pm2 info MagicMirror
                          again
                          • 1 Offline
                            @sdetweil I installed the software like in the docs show. So I haven`t installed pm2
                              @1blaunitrox said in updateDom() blocks MagicMirror:
                              the fixuppm2 installs it if needed
                              but u had it installed cause you used it to launch MM…
                                my script fixes little odds and ends not covered by the doc
