    updateDom() blocks MagicMirror
    28 Posts 2 Posters 10.1k Views 2 Watching
      1BlauNitrox @sdetweil
      Not exectly what I wanted :joy:
      Why can getDom() not transfrom the array in a readable string?
        sdetweil @1BlauNitrox
        @1blaunitrox yes, this.response is an object
                this.response = {
                    "name": "Test",
                    "entries": {
                        "lessions": "Teacher Subject Room representation"
        html doesn’t know objects
        1 1 Reply Last reply Reply Quote 0
          @sdetweil Is there a Json parser I can use?
            @1blaunitrox said in updateDom() blocks MagicMirror:
            getDom() CAN do anythign YOU implement… it does NOTHING by itself…
            S 1 2 Replies Last reply Reply Quote 0
              @sdetweil JSON.parse, JSON. stringify
              u have an object so, stringify turns it into text
              parse takes text and makes an object
                @sdetweil What about JSON.stringify(this.response);
                  @1blaunitrox that would work
                  but it will be the JSON text representation of the object
                  all fields and values
                    First: Is there an other option?
                    Second: I added the getData() function in getDom()
                            const wrapper = document.createElement("div");
                            this.getData();
                            if(this.response.lenght <= 0) {
                                wrapper.innerHTML = "No Entries";
                            } else {
                                wrapper.innerHTML = JSON.stringify(this.response);
                            return wrapper;
                    Now the mirror show UNDEFINED again
                      @1blaunitrox length
                      spelling matters…
                      use the debugger
                        @1blaunitrox this.getData() is not synchronous, so it will return long before the data is ready
                        don’t call from getDom()
                          see the doc
                          https://docs.magicmirror.builders/development/introduction.html#module-structure
                          https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
                          notificationReceived in particular
                            @sdetweil Do you remember my problem yesteray that my magic mirror doesn`t start? I started the program today in the morning. Without doing anythink since yesterday evening, the same error occurs.
                            The only think I change was that I renamed lenght to length. Than I deleted the module module and copyed the new one.
                            old post: https://forum.magicmirror.builders/topic/16233/error-while-starting-magic-mirror/29
                              @1blaunitrox I need to see the messages output by npm start
                              if you use pm2, then pm2 logs --lines=50
                              also maybe info from the developers window, ctrl-shift-i on the keyboard and select the console tab and scroll up to see any errors red text
                                Here is the .pm2/logs/MagicMirror-error.log
                                https://haste.lyrotopia.net/equzexapal.js
                                Its always the same error
                                Here is the .pm2/logs/MagicMirror-out.log
                                https://haste.lyrotopia.net/mosubanoro.css
                                  @1blaunitrox ok, weird…
                                  npm -v
                                  node -v
                                  which user is pm2 installed on?
                                  pm2 info 0
                                      @1blaunitrox ok, do this
                                      pm2 stop all
                                      pm2 delete 0
                                      pm2 save
                                      the run my fixuppm2.sh script from here
                                        @sdetweil I installed the software again. Now it works, but I think I will see this error soon again.
                                        btw: I wrote an issues on git: https://github.com/MichMich/MagicMirror/issues/2793
                                          @1blaunitrox i saw the git issue
                                          can u do pm2 info MagicMirror
                                          again
                                            @sdetweil I installed the software like in the docs show. So I haven`t installed pm2
