    updateDom() blocks MagicMirror
    28 Posts 2 Posters 9.8k Views 2 Watching
      sdetweil @1BlauNitrox
      @1blaunitrox yes, this.response is an object
              this.response = {
                  "name": "Test",
                  "entries": {
                      "lessions": "Teacher Subject Room representation"
      html doesn’t know objects
      1 1 Reply Last reply Reply Quote 0
      • 1 Offline
        1BlauNitrox @sdetweil
        @sdetweil Is there a Json parser I can use?
          @1blaunitrox said in updateDom() blocks MagicMirror:
          Why can getDom() not transfrom the array in a readable string?
          getDom() CAN do anythign YOU implement… it does NOTHING by itself…
          S 1 2 Replies Last reply Reply Quote 0
            @sdetweil JSON.parse, JSON. stringify
            u have an object so, stringify turns it into text
            parse takes text and makes an object
            • 1 Offline
              @sdetweil What about JSON.stringify(this.response);
                @1blaunitrox that would work
                but it will be the JSON text representation of the object
                all fields and values
                • 1 Offline
                  First: Is there an other option?
                  Second: I added the getData() function in getDom()
                          const wrapper = document.createElement("div");
                          this.getData();
                          if(this.response.lenght <= 0) {
                              wrapper.innerHTML = "No Entries";
                          } else {
                              wrapper.innerHTML = JSON.stringify(this.response);
                          return wrapper;
                  Now the mirror show UNDEFINED again
                    @1blaunitrox length
                    spelling matters…
                    use the debugger
                      @1blaunitrox this.getData() is not synchronous, so it will return long before the data is ready
                      don’t call from getDom()
                        see the doc
                        https://docs.magicmirror.builders/development/introduction.html#module-structure
                        https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
                        notificationReceived in particular
                        • 1 Offline
                          @sdetweil Do you remember my problem yesteray that my magic mirror doesn`t start? I started the program today in the morning. Without doing anythink since yesterday evening, the same error occurs.
                          The only think I change was that I renamed lenght to length. Than I deleted the module module and copyed the new one.
                          old post: https://forum.magicmirror.builders/topic/16233/error-while-starting-magic-mirror/29
                            @1blaunitrox I need to see the messages output by npm start
                            if you use pm2, then pm2 logs --lines=50
                            also maybe info from the developers window, ctrl-shift-i on the keyboard and select the console tab and scroll up to see any errors red text
                            • 1 Offline
                              Here is the .pm2/logs/MagicMirror-error.log
                              https://haste.lyrotopia.net/equzexapal.js
                              Its always the same error
                              Here is the .pm2/logs/MagicMirror-out.log
                              https://haste.lyrotopia.net/mosubanoro.css
                                @1blaunitrox ok, weird…
                                npm -v
                                node -v
                                which user is pm2 installed on?
                                pm2 info 0
                                • 1 Offline
                                    @1blaunitrox ok, do this
                                    pm2 stop all
                                    pm2 delete 0
                                    pm2 save
                                    the run my fixuppm2.sh script from here
                                    • 1 Offline
                                      @sdetweil I installed the software again. Now it works, but I think I will see this error soon again.
                                      btw: I wrote an issues on git: https://github.com/MichMich/MagicMirror/issues/2793
                                        @1blaunitrox i saw the git issue
                                        can u do pm2 info MagicMirror
                                        again
                                        • 1 Offline
                                          @sdetweil I installed the software like in the docs show. So I haven`t installed pm2
                                            the fixuppm2 installs it if needed
                                            but u had it installed cause you used it to launch MM…
