    updateDom() blocks MagicMirror
    28 Posts 2 Posters 8.9k Views 2 Watching
    • 1 Offline
      1BlauNitrox
      Hey,
      I am developing my own first module. Therefore I looked at some other modules and in the dev documentation.
      This is what I have right now:
      Module.register("MMM-VPlan", {
      	defaults: {
      		fadeSpeed: 2,
                      username: "",
                      password: ""
      	getStyles: function() {
              return ["MMM-Plan.css"];
          start: function() {
      		Log.log("Starting module: " + this.name);
              this.response = {
                  "name": "Test",
                  "entries": {
                      "lessions": "Teacher Subject Room representation"
      		//this.getData();
              updateDom();
      	getDom: function() {
              const wrapper = document.createElement("div");
              wrapper.innerHTML = response;
              return wrapper;
          getData: function () {
              const request = new XMLHttpRequest();
              request.open('GET', 'http://localhost/vplan/' + username + '/' + password + '/today', true);
              request.onreadystatechange = () => {
                if (request.readyState != 4) {
                  return;
                if (request.status === 200) {
                  this.response = JSON.parse(request.response);
                  this.updateDom();
                } else {
                  Log.error(`${this.name}: Could not load data`);
                setTimeout(() => this.getData(), this.config.updateIntervalMs);
              request.send();
      The getData() function is not in use.
      My problem is the getDom() function. If I call updateDom() in the start method, the mirror shows only a black screen without any content. Even the other modules aren`t visible.
      If I delete updateDom() in the start methode, the mirror shows all modules. But my module returns undefined:
      S 3 Replies Last reply Reply Quote 0
        sdetweil @1BlauNitrox
        @1blaunitrox said in updateDom() blocks MagicMirror:
        where is response?
        i think u meant this.response
        don’t call updateDom() in start
        mm will call it the 1st time when the module is loaded
        note that this.response might be empty in a real life situation, but you MUST return something
        an empty div is ok… (it IS something)
        1 1 Reply Last reply Reply Quote 0
          @1blaunitrox you can walk thru the module code in the developers window sources tab
          ctrl-shift-i,
          source tab
          left nav, navigate to modules, your module name, click your modulename.js
          source on the right
          click on a source line, left edge to turn on a break point
          hit f5 to refresh , will stop
          upper right arrow is run, next is step, next is into, next is over
          mouse hover over variables for value/content
          u can use chrome (firefox/edge) on the pc if u allow remote connection in config.js
          address:"0.0.0.0".
          ipWhitelist:[],
            @1blaunitrox the black screen is cause your module source crashed the browser… oops…
            its this.updateDom()
            look at my sample module
            https://github.com/sdetweil/SampleModule
            • 1 Offline
              1BlauNitrox @sdetweil
              @sdetweil I changed getDom() to this:
                      if(response.lenght <= 0) {
                          wrapper.innerHTML = "No Entries";
                      } else {
                          wrapper.innerHTML = this.response;
                      return wrapper;
              There is a check if the array has any entries.
              But the mirror shows “undefined”
                this.response.length
                always gotta use this.
                unless u created the variable INSIDE the routine using it…
                use the debugger
                • 1 Offline
                  Not exectly what I wanted :joy:
                  Why can getDom() not transfrom the array in a readable string?
                    @1blaunitrox yes, this.response is an object
                            this.response = {
                                "name": "Test",
                                "entries": {
                    html doesn’t know objects
                    • 1 Offline
                      @sdetweil Is there a Json parser I can use?
                        getDom() CAN do anythign YOU implement… it does NOTHING by itself…
                        S 1 2 Replies Last reply Reply Quote 0
                          @sdetweil JSON.parse, JSON. stringify
                          u have an object so, stringify turns it into text
                          parse takes text and makes an object
                          • 1 Offline
                            @sdetweil What about JSON.stringify(this.response);
                              @1blaunitrox that would work
                              but it will be the JSON text representation of the object
                              all fields and values
                              • 1 Offline
                                First: Is there an other option?
                                Second: I added the getData() function in getDom()
                                        this.getData();
                                        if(this.response.lenght <= 0) {
                                        } else {
                                            wrapper.innerHTML = JSON.stringify(this.response);
                                        return wrapper;
                                Now the mirror show UNDEFINED again
                                  @1blaunitrox length
                                  spelling matters…
                                  use the debugger
                                    @1blaunitrox this.getData() is not synchronous, so it will return long before the data is ready
                                    don’t call from getDom()
                                      see the doc
                                      https://docs.magicmirror.builders/development/introduction.html#module-structure
                                      https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
                                      notificationReceived in particular
                                      • 1 Offline
                                        @sdetweil Do you remember my problem yesteray that my magic mirror doesn`t start? I started the program today in the morning. Without doing anythink since yesterday evening, the same error occurs.
                                        The only think I change was that I renamed lenght to length. Than I deleted the module module and copyed the new one.
                                        old post: https://forum.magicmirror.builders/topic/16233/error-while-starting-magic-mirror/29
                                          @1blaunitrox I need to see the messages output by npm start
                                          if you use pm2, then pm2 logs --lines=50
                                          also maybe info from the developers window, ctrl-shift-i on the keyboard and select the console tab and scroll up to see any errors red text
                                          • 1 Offline
                                            Here is the .pm2/logs/MagicMirror-error.log
                                            https://haste.lyrotopia.net/equzexapal.js
                                            Its always the same error
                                            Here is the .pm2/logs/MagicMirror-out.log
                                            https://haste.lyrotopia.net/mosubanoro.css
