    updateDom() blocks MagicMirror
    28 Posts 2 Posters 10.1k Views 2 Watching
      sdetweil @1BlauNitrox
      @1blaunitrox you can walk thru the module code in the developers window sources tab
      ctrl-shift-i,
      source tab
      left nav, navigate to modules, your module name, click your modulename.js
      source on the right
      click on a source line, left edge to turn on a break point
      hit f5 to refresh , will stop
      upper right arrow is run, next is step, next is into, next is over
      mouse hover over variables for value/content
      u can use chrome (firefox/edge) on the pc if u allow remote connection in config.js
      address:"0.0.0.0".
      ipWhitelist:[],
        @1blaunitrox the black screen is cause your module source crashed the browser… oops…
        its this.updateDom()
        look at my sample module
        https://github.com/sdetweil/SampleModule
          1BlauNitrox @sdetweil
          @sdetweil I changed getDom() to this:
          getDom: function() {
                  const wrapper = document.createElement("div");
                  if(response.lenght <= 0) {
                      wrapper.innerHTML = "No Entries";
                  } else {
                      wrapper.innerHTML = this.response;
                  return wrapper;
          There is a check if the array has any entries.
          But the mirror shows “undefined”
            @1blaunitrox said in updateDom() blocks MagicMirror:
            this.response.length
            always gotta use this.
            unless u created the variable INSIDE the routine using it…
            use the debugger
            1 1 Reply Last reply Reply Quote 0
              Not exectly what I wanted :joy:
              Why can getDom() not transfrom the array in a readable string?
                @1blaunitrox yes, this.response is an object
                        this.response = {
                            "name": "Test",
                            "entries": {
                                "lessions": "Teacher Subject Room representation"
                html doesn’t know objects
                  @sdetweil Is there a Json parser I can use?
                    getDom() CAN do anythign YOU implement… it does NOTHING by itself…
                    S 1 2 Replies Last reply Reply Quote 0
                      @sdetweil JSON.parse, JSON. stringify
                      u have an object so, stringify turns it into text
                      parse takes text and makes an object
                        @sdetweil What about JSON.stringify(this.response);
                          @1blaunitrox that would work
                          but it will be the JSON text representation of the object
                          all fields and values
                            First: Is there an other option?
                            Second: I added the getData() function in getDom()
                                    this.getData();
                                    if(this.response.lenght <= 0) {
                                    } else {
                                        wrapper.innerHTML = JSON.stringify(this.response);
                                    return wrapper;
                            Now the mirror show UNDEFINED again
                              @1blaunitrox length
                              spelling matters…
                              use the debugger
                                @1blaunitrox this.getData() is not synchronous, so it will return long before the data is ready
                                don’t call from getDom()
                                  see the doc
                                  https://docs.magicmirror.builders/development/introduction.html#module-structure
                                  https://docs.magicmirror.builders/development/core-module-file.html#subclassable-module-methods
                                  notificationReceived in particular
                                    @sdetweil Do you remember my problem yesteray that my magic mirror doesn`t start? I started the program today in the morning. Without doing anythink since yesterday evening, the same error occurs.
                                    The only think I change was that I renamed lenght to length. Than I deleted the module module and copyed the new one.
                                    old post: https://forum.magicmirror.builders/topic/16233/error-while-starting-magic-mirror/29
                                      @1blaunitrox I need to see the messages output by npm start
                                      if you use pm2, then pm2 logs --lines=50
                                      also maybe info from the developers window, ctrl-shift-i on the keyboard and select the console tab and scroll up to see any errors red text
                                        Here is the .pm2/logs/MagicMirror-error.log
                                        https://haste.lyrotopia.net/equzexapal.js
                                        Its always the same error
                                        Here is the .pm2/logs/MagicMirror-out.log
                                        https://haste.lyrotopia.net/mosubanoro.css
                                          @1blaunitrox ok, weird…
                                          npm -v
                                          node -v
                                          which user is pm2 installed on?
                                          pm2 info 0
