    updateDom() blocks MagicMirror
    28 Posts 2 Posters 8.5k Views 2 Watching
      sdetweil @1BlauNitrox
      @1blaunitrox you can walk thru the module code in the developers window sources tab
      ctrl-shift-i,
      source tab
      left nav, navigate to modules, your module name, click your modulename.js
      source on the right
      click on a source line, left edge to turn on a break point
      hit f5 to refresh , will stop
      upper right arrow is run, next is step, next is into, next is over
      mouse hover over variables for value/content
      u can use chrome (firefox/edge) on the pc if u allow remote connection in config.js
      address:"0.0.0.0".
      ipWhitelist:[],
        @1blaunitrox the black screen is cause your module source crashed the browser… oops…
        its this.updateDom()
        look at my sample module
        https://github.com/sdetweil/SampleModule
        • 1 Offline
          1BlauNitrox @sdetweil
          @sdetweil I changed getDom() to this:
          getDom: function() {
                  const wrapper = document.createElement("div");
                  if(response.lenght <= 0) {
                      wrapper.innerHTML = "No Entries";
                  } else {
                      wrapper.innerHTML = this.response;
                  return wrapper;
          There is a check if the array has any entries.
          But the mirror shows “undefined”
            @1blaunitrox said in updateDom() blocks MagicMirror:
            this.response.length
            always gotta use this.
            unless u created the variable INSIDE the routine using it…
            use the debugger
            1 1 Reply Last reply Reply Quote 0
            • 1 Offline
              Not exectly what I wanted :joy:
              Why can getDom() not transfrom the array in a readable string?
                @1blaunitrox yes, this.response is an object
                        this.response = {
                            "name": "Test",
                            "entries": {
                                "lessions": "Teacher Subject Room representation"
                html doesn’t know objects
                • 1 Offline
                  @sdetweil Is there a Json parser I can use?
                    getDom() CAN do anythign YOU implement… it does NOTHING by itself…
                    S 1 2 Replies Last reply Reply Quote 0
                      @sdetweil JSON.parse, JSON. stringify
                      u have an object so, stringify turns it into text
                      parse takes text and makes an object
                      • 1 Offline
                        @sdetweil What about JSON.stringify(this.response);
