Help. MM doesn't work Anymore
10 Posts 3 Posters 964 Views 3 Watching
  • E Offline
    Extra
    I had installed a module called on-this-day and now my MM doesn’t work. I uninstalled it and it still doesn’t work. I get this error:
    > magicmirror@2.18.0 start
    [22.01.2022 20:01.34.583] [LOG]   Starting MagicMirror: v2.18.0
    [22.01.2022 20:01.34.621] [LOG]   Loading config ...
    [22.01.2022 20:01.34.650] [LOG]   Loading module helpers ...
    [22.01.2022 20:01.34.661] [LOG]   No helper found for module: alert.
    [22.01.2022 20:01.34.746] [LOG]   Initializing new module helper ...
    [22.01.2022 20:01.34.751] [LOG]   Module helper loaded: updatenotification
    [22.01.2022 20:01.34.757] [LOG]   No helper found for module: clock.
    [22.01.2022 20:01.36.053] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
    Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules.
    [22.01.2022 20:01.36.058] [LOG]   Loading module helpers ...
    [22.01.2022 20:01.36.062] [LOG]   No helper found for module: alert.
    [22.01.2022 20:01.36.066] [LOG]   Initializing new module helper ...
    [22.01.2022 20:01.36.068] [LOG]   Module helper loaded: updatenotification
    [22.01.2022 20:01.36.072] [LOG]   No helper found for module: clock.
    [22.01.2022 20:01.36.215] [ERROR] App threw an error during load
    [22.01.2022 20:01.36.218] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
        at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:11:15)
        at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:25)
        at loadModule (/home/pi/MagicMirror/js/app.js:127:19)
        at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5)
        at /home/pi/MagicMirror/js/app.js:167:6
        at loadModule (/home/pi/MagicMirror/js/app.js:146:4)
        at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3)
        at loadModule (/home/pi/MagicMirror/js/app.js:144:6)
        at loadModules (/home/pi/MagicMirror/js/app.js:176:3)
        at /home/pi/MagicMirror/js/app.js:225:4
        at loadConfig (/home/pi/MagicMirror/js/app.js:81:4)
        at App.start (/home/pi/MagicMirror/js/app.js:212:3)
        at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:153:7)
        at loadApplicationPackage (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16)
        at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9)
        at Object.<anonymous> (node:electron/js2c/browser_init:193:3197)
        at Object../lib/browser/init.ts (node:electron/js2c/browser_init:193:3401)
        at __webpack_require__ (node:electron/js2c/browser_init:1:128)
        at node:electron/js2c/browser_init:1:1200
        at node:electron/js2c/browser_init:1:1267
    [22.01.2022 20:01.36.224] [ERROR] Whoops! There was an uncaught exception...
    [22.01.2022 20:01.36.282] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
        at Function.c._load (node:electron/js2c/asar_bundle:5:13331) {
      code: 'ERR_REQUIRE_ESM'
    [22.01.2022 20:01.36.293] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
    [22.01.2022 20:01.36.295] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
    [22.01.2022 20:01.38.394] [LOG]   Launching application.
    [12298:0122/200144.333810:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
    [12329:0122/200145.375493:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
    [22.01.2022 20:01.58.391] [LOG]   Shutting down server...
    [22.01.2022 20:01.58.398] [LOG]   Stopping module helper: updatenotification
    [22.01.2022 20:01.58.401] [LOG]   Stopping module helper: updatenotification
    [22.01.2022 20:01.58.406] [ERROR] Whoops! There was an uncaught exception...
    [22.01.2022 20:01.58.410] [ERROR] TypeError: Cannot read properties of undefined (reading 'close')
        at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
        at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7)
        at App.emit (node:events:394:28)
        at appMethod (node:electron/js2c/browser_init:69:1830)
        at Object.execute (node:electron/js2c/browser_init:69:5623)
        at MenuItem.click (node:electron/js2c/browser_init:73:1862)
        at Object.a._executeCommand (node:electron/js2c/browser_init:81:2453)
    [22.01.2022 20:01.58.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
    [22.01.2022 20:01.58.417] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
    Can someone help me fix this?
    S 1 Reply Last reply Jan 23, 2022, 1:55 AM Reply Quote 0
      sdetweil @Extra
      @extra do
      rm -rf node_modules
      rm package-lock.json
      npm install --only=prod
      then try starting
      E 1 Reply Last reply Jan 23, 2022, 6:51 PM Reply Quote 0
      • E Offline
        Extra @sdetweil
        @sdetweil No, sadly this didn’t work. I still get the same error and a blank black screen.
        Is there anything else I can do? Or do I have to uninstall and reinstall MM?
        S 1 Reply Last reply Jan 23, 2022, 7:51 PM Reply Quote 0
          sdetweil @Extra
          @extra no, need to seek the messages now
          where u do npm start
          if using pm2 then
          pm2 logs --lines=50
          E 1 Reply Last reply Jan 23, 2022, 7:59 PM Reply Quote 0
          • E Offline
            Extra @sdetweil
            @sdetweil I do npm start in
            ~/MagicMirror/modules/MMM-SmartTouch
            I don’t use pm2
            ~/MagicMirror/modules/MMM-SmartTouch $ pm2 logs--lines=50
            [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
            [PM2] PM2 Successfully daemonized
            [PM2][ERROR] Command not found
            usage: pm2 [options] <command>
            pm2 -h, --help             all available commands and options
            pm2 examples               display pm2 usage examples
            pm2 <command> -h           help on a specific command
            Access pm2 files in ~/.pm2
            ~/MagicMirror/modules/MMM-SmartTouch $ npm start
            [23.01.2022 14:55.16.782] [LOG]   Starting MagicMirror: v2.18.0
            [23.01.2022 14:55.16.820] [LOG]   Loading config ...
            [23.01.2022 14:55.16.861] [LOG]   Loading module helpers ...
            [23.01.2022 14:55.16.877] [LOG]   No helper found for module: alert.
            [23.01.2022 14:55.16.929] [LOG]   Initializing new module helper ...
            [23.01.2022 14:55.16.932] [LOG]   Module helper loaded: updatenotification
            [23.01.2022 14:55.16.934] [LOG]   No helper found for module: clock.
            [23.01.2022 14:55.17.400] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
            [23.01.2022 14:55.17.403] [LOG]   Loading module helpers ...
            [23.01.2022 14:55.17.406] [LOG]   No helper found for module: alert.
            [23.01.2022 14:55.17.408] [LOG]   Initializing new module helper ...
            [23.01.2022 14:55.17.409] [LOG]   Module helper loaded: updatenotification
            [23.01.2022 14:55.17.416] [LOG]   No helper found for module: clock.
            [23.01.2022 14:55.17.485] [ERROR] App threw an error during load
            [23.01.2022 14:55.17.487] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
            [23.01.2022 14:55.17.489] [ERROR] Whoops! There was an uncaught exception...
            [23.01.2022 14:55.17.502] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported.
            [23.01.2022 14:55.17.508] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [23.01.2022 14:55.17.509] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [23.01.2022 14:55.18.455] [LOG]   Launching application.
            [1416:0123/145520.523134:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
            [1446:0123/145521.167121:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
            [23.01.2022 14:55.24.239] [LOG]   Shutting down server...
            [23.01.2022 14:55.24.245] [LOG]   Stopping module helper: updatenotification
            [23.01.2022 14:55.24.246] [LOG]   Stopping module helper: updatenotification
            [23.01.2022 14:55.24.248] [ERROR] Whoops! There was an uncaught exception...
            [23.01.2022 14:55.24.252] [ERROR] TypeError: Cannot read properties of undefined (reading 'close')
            [23.01.2022 14:55.24.255] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [23.01.2022 14:55.24.258] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            S M 2 Replies Last reply Jan 23, 2022, 8:42 PM Reply Quote 0
              sdetweil @Extra
              @extra so, what have you done
              did those commands
              black screen
              and since then?
              this looks like you did an npm install in the wrong folder
              E 1 Reply Last reply Jan 23, 2022, 8:57 PM Reply Quote 0
              • E Offline
                Extra @sdetweil
                @sdetweil I just copied my config file to a usb, uninstalled MM, and re-installed it and replaced the config file with the one from my usb. It’s back to normal now.
                I appreciate the help though. Thanks again.
                S 1 Reply Last reply Jan 23, 2022, 8:58 PM Reply Quote 0
                  sdetweil @Extra
                  @extra how did u install?
                  E 1 Reply Last reply Jan 23, 2022, 9:05 PM Reply Quote 0
                  • E Offline
                    Extra @sdetweil
                    @sdetweil I followed the steps on the docs (manual installation): https://docs.magicmirror.builders/getting-started/installation.html
                    Then downloaded the MMM-SmartTouch module and followed those setup instructions here: https://github.com/EbenKouao/MMM-SmartTouch
                      mumblebaj Module Developer @Extra
                      @extra said in Help. MM doesn't work Anymore:
                      This is the wrong version of node-fetch that is installed on MM. You need to downgrade node-fetch to v2.6.1 or something earlier than v3 where the module was change to an ES module. I would uninstall node-fetch and check which module uses it and what specific version and install the correct version.
