Help. MM doesn't work Anymore
I had installed a module called on-this-day and now my MM doesn’t work. I uninstalled it and it still doesn’t work. I get this error:
> magicmirror@2.18.0 start > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [22.01.2022 20:01.34.583] [LOG] Starting MagicMirror: v2.18.0 [22.01.2022 20:01.34.621] [LOG] Loading config ... [22.01.2022 20:01.34.650] [LOG] Loading module helpers ... [22.01.2022 20:01.34.661] [LOG] No helper found for module: alert. [22.01.2022 20:01.34.746] [LOG] Initializing new module helper ... [22.01.2022 20:01.34.751] [LOG] Module helper loaded: updatenotification [22.01.2022 20:01.34.757] [LOG] No helper found for module: clock. [22.01.2022 20:01.36.053] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported. Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules. [22.01.2022 20:01.36.058] [LOG] Loading module helpers ... [22.01.2022 20:01.36.062] [LOG] No helper found for module: alert. [22.01.2022 20:01.36.066] [LOG] Initializing new module helper ... [22.01.2022 20:01.36.068] [LOG] Module helper loaded: updatenotification [22.01.2022 20:01.36.072] [LOG] No helper found for module: clock. [22.01.2022 20:01.36.215] [ERROR] App threw an error during load [22.01.2022 20:01.36.218] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported. Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules. at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:11:15) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:25) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadModule (/home/pi/MagicMirror/js/app.js:127:19) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3) at loadModule (/home/pi/MagicMirror/js/app.js:144:6) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at loadModules (/home/pi/MagicMirror/js/app.js:176:3) at /home/pi/MagicMirror/js/app.js:225:4 at loadConfig (/home/pi/MagicMirror/js/app.js:81:4) at App.start (/home/pi/MagicMirror/js/app.js:212:3) at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:153:7) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadApplicationPackage (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (node:electron/js2c/browser_init:193:3197) at Object../lib/browser/init.ts (node:electron/js2c/browser_init:193:3401) at __webpack_require__ (node:electron/js2c/browser_init:1:128) at node:electron/js2c/browser_init:1:1200 at node:electron/js2c/browser_init:1:1267 at Function.c._load (node:electron/js2c/asar_bundle:5:13331) [22.01.2022 20:01.36.224] [ERROR] Whoops! There was an uncaught exception... [22.01.2022 20:01.36.282] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported. Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules. at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:11:15) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:25) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadModule (/home/pi/MagicMirror/js/app.js:127:19) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3) at loadModule (/home/pi/MagicMirror/js/app.js:144:6) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at loadModules (/home/pi/MagicMirror/js/app.js:176:3) at /home/pi/MagicMirror/js/app.js:225:4 at loadConfig (/home/pi/MagicMirror/js/app.js:81:4) at App.start (/home/pi/MagicMirror/js/app.js:212:3) at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:153:7) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadApplicationPackage (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (node:electron/js2c/browser_init:193:3197) at Object../lib/browser/init.ts (node:electron/js2c/browser_init:193:3401) at __webpack_require__ (node:electron/js2c/browser_init:1:128) at node:electron/js2c/browser_init:1:1200 at node:electron/js2c/browser_init:1:1267 at Function.c._load (node:electron/js2c/asar_bundle:5:13331) { code: 'ERR_REQUIRE_ESM' } [22.01.2022 20:01.36.293] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [22.01.2022 20:01.36.295] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [22.01.2022 20:01.38.394] [LOG] Launching application. [12298:0122/200144.333810:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization [12329:0122/200145.375493:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process. [22.01.2022 20:01.58.391] [LOG] Shutting down server... [22.01.2022 20:01.58.398] [LOG] Stopping module helper: updatenotification [22.01.2022 20:01.58.401] [LOG] Stopping module helper: updatenotification [22.01.2022 20:01.58.406] [ERROR] Whoops! There was an uncaught exception... [22.01.2022 20:01.58.410] [ERROR] TypeError: Cannot read properties of undefined (reading 'close') at App.stop (/home/pi/MagicMirror/js/app.js:257:14) at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7) at App.emit (node:events:394:28) at appMethod (node:electron/js2c/browser_init:69:1830) at Object.execute (node:electron/js2c/browser_init:69:5623) at MenuItem.click (node:electron/js2c/browser_init:73:1862) at Object.a._executeCommand (node:electron/js2c/browser_init:81:2453) [22.01.2022 20:01.58.414] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [22.01.2022 20:01.58.417] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issuesCan someone help me fix this?
@extra do
cd ~/MagicMirror rm -rf node_modules rm package-lock.json npm install --only=prodthen try starting
@sdetweil No, sadly this didn’t work. I still get the same error and a blank black screen.
Is there anything else I can do? Or do I have to uninstall and reinstall MM? -
@sdetweil I do npm start in
~/MagicMirror/modules/MMM-SmartTouchI don’t use pm2
~/MagicMirror/modules/MMM-SmartTouch $ pm2 logs--lines=50 [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2 [PM2] PM2 Successfully daemonized [PM2][ERROR] Command not found usage: pm2 [options] <command> pm2 -h, --help all available commands and options pm2 examples display pm2 usage examples pm2 <command> -h help on a specific command Access pm2 files in ~/.pm2 ~/MagicMirror/modules/MMM-SmartTouch $ npm start > magicmirror@2.18.0 start > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [23.01.2022 14:55.16.782] [LOG] Starting MagicMirror: v2.18.0 [23.01.2022 14:55.16.820] [LOG] Loading config ... [23.01.2022 14:55.16.861] [LOG] Loading module helpers ... [23.01.2022 14:55.16.877] [LOG] No helper found for module: alert. [23.01.2022 14:55.16.929] [LOG] Initializing new module helper ... [23.01.2022 14:55.16.932] [LOG] Module helper loaded: updatenotification [23.01.2022 14:55.16.934] [LOG] No helper found for module: clock. [23.01.2022 14:55.17.400] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported. Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules. [23.01.2022 14:55.17.403] [LOG] Loading module helpers ... [23.01.2022 14:55.17.406] [LOG] No helper found for module: alert. [23.01.2022 14:55.17.408] [LOG] Initializing new module helper ... [23.01.2022 14:55.17.409] [LOG] Module helper loaded: updatenotification [23.01.2022 14:55.17.416] [LOG] No helper found for module: clock. [23.01.2022 14:55.17.485] [ERROR] App threw an error during load [23.01.2022 14:55.17.487] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported. Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules. at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:11:15) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:25) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadModule (/home/pi/MagicMirror/js/app.js:127:19) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3) at loadModule (/home/pi/MagicMirror/js/app.js:144:6) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at loadModules (/home/pi/MagicMirror/js/app.js:176:3) at /home/pi/MagicMirror/js/app.js:225:4 at loadConfig (/home/pi/MagicMirror/js/app.js:81:4) at App.start (/home/pi/MagicMirror/js/app.js:212:3) at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:153:7) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadApplicationPackage (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (node:electron/js2c/browser_init:193:3197) at Object../lib/browser/init.ts (node:electron/js2c/browser_init:193:3401) at __webpack_require__ (node:electron/js2c/browser_init:1:128) at node:electron/js2c/browser_init:1:1200 at node:electron/js2c/browser_init:1:1267 at Function.c._load (node:electron/js2c/asar_bundle:5:13331) [23.01.2022 14:55.17.489] [ERROR] Whoops! There was an uncaught exception... [23.01.2022 14:55.17.502] [ERROR] Error [ERR_REQUIRE_ESM]: require() of ES Module /home/pi/MagicMirror/node_modules/node-fetch/src/index.js from /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js not supported. Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules. at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:11:15) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:8:25) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadModule (/home/pi/MagicMirror/js/app.js:127:19) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at Class.loaded (/home/pi/MagicMirror/js/node_helper.js:18:3) at loadModule (/home/pi/MagicMirror/js/app.js:144:6) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at /home/pi/MagicMirror/js/app.js:167:6 at loadModule (/home/pi/MagicMirror/js/app.js:146:4) at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) at loadModules (/home/pi/MagicMirror/js/app.js:176:3) at /home/pi/MagicMirror/js/app.js:225:4 at loadConfig (/home/pi/MagicMirror/js/app.js:81:4) at App.start (/home/pi/MagicMirror/js/app.js:212:3) at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:153:7) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at loadApplicationPackage (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:110:16) at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:222:9) at Function.c._load (node:electron/js2c/asar_bundle:5:13331) at Object.<anonymous> (node:electron/js2c/browser_init:193:3197) at Object../lib/browser/init.ts (node:electron/js2c/browser_init:193:3401) at __webpack_require__ (node:electron/js2c/browser_init:1:128) at node:electron/js2c/browser_init:1:1200 at node:electron/js2c/browser_init:1:1267 at Function.c._load (node:electron/js2c/asar_bundle:5:13331) { code: 'ERR_REQUIRE_ESM' } [23.01.2022 14:55.17.508] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [23.01.2022 14:55.17.509] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues [23.01.2022 14:55.18.455] [LOG] Launching application. [1416:0123/145520.523134:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization [1446:0123/145521.167121:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process. [23.01.2022 14:55.24.239] [LOG] Shutting down server... [23.01.2022 14:55.24.245] [LOG] Stopping module helper: updatenotification [23.01.2022 14:55.24.246] [LOG] Stopping module helper: updatenotification [23.01.2022 14:55.24.248] [ERROR] Whoops! There was an uncaught exception... [23.01.2022 14:55.24.252] [ERROR] TypeError: Cannot read properties of undefined (reading 'close') at App.stop (/home/pi/MagicMirror/js/app.js:257:14) at App.<anonymous> (/home/pi/MagicMirror/js/electron.js:139:7) at App.emit (node:events:394:28) at appMethod (node:electron/js2c/browser_init:69:1830) at Object.execute (node:electron/js2c/browser_init:69:5623) at MenuItem.click (node:electron/js2c/browser_init:73:1862) at Object.a._executeCommand (node:electron/js2c/browser_init:81:2453) [23.01.2022 14:55.24.255] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [23.01.2022 14:55.24.258] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues -
@extra so, what have you done
did those commands
black screen
and since then?this looks like you did an npm install in the wrong folder
@sdetweil I just copied my config file to a usb, uninstalled MM, and re-installed it and replaced the config file with the one from my usb. It’s back to normal now.
I appreciate the help though. Thanks again.
@extra how did u install?
@sdetweil I followed the steps on the docs (manual installation): https://docs.magicmirror.builders/getting-started/installation.html
Then downloaded the MMM-SmartTouch module and followed those setup instructions here: https://github.com/EbenKouao/MMM-SmartTouch
@extra said in Help. MM doesn't work Anymore:
Instead change the require of index.js in /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js to a dynamic import() which is available in all CommonJS modules.This is the wrong version of node-fetch that is installed on MM. You need to downgrade node-fetch to v2.6.1 or something earlier than v3 where the module was change to an ES module. I would uninstall node-fetch and check which module uses it and what specific version and install the correct version.
