    raspi 64 bit available
    15 Posts 5 Posters 6.5k Views 5 Watching
      see
      https://www.raspberrypi.com/news/raspberry-pi-os-64-bit/
      note the issues w 64 bit chromium in the text
      karsten13K BKeyportB 2 Replies Last reply Reply Quote 2
      • karsten13K Offline
        karsten13 @sdetweil
        my pi4 is now running with 64bit, mm runs out of the box (docker setup as always).
        karsten13K 1 Reply Last reply Reply Quote 2
          karsten13 @karsten13
          pi zero 2w works too.
          Off topic: Did not expect that motioneye with raspicam (running in docker buster image) is working.
          • BKeyportB Offline
            Just for the fun of it, I’m installing it on the test box…
            Seems your script has issues with it…
            Also, with this - Rasp Imager got an update, too - It’s got lots of config changes now, so make sure you check out the gear icon when writing!
            S B 2 Replies Last reply Reply Quote 0
              sdetweil @BKeyport
              @bkeyport thx. I am away from my pi devices til middle of march.
                karsten13 @sdetweil
                Meanwhile I digged into pi specific setup.
                Real bad is that they removed /opt/vc and integrated the pi specific stuff into the normal file system under /lib and /usr.
                With a docker setup I could formerly just mount /opt/vc into the container which is impossible now.
                E.g. for getting vcgencmd working in the container I have to mount
                now
                      - /lib/aarch64-linux-gnu/libvchiq_arm.so:/lib/aarch64-linux-gnu/libvchiq_arm.so.0:ro
                      - /lib/aarch64-linux-gnu/libvcos.so:/lib/aarch64-linux-gnu/libvcos.so.0:ro
                      - /usr/bin/vcgencmd:/usr/bin/vcgencmd
                after using ldd to know which libraries are used.
                Other possibility would be to install the pi specific libraries into the docker image which will explode size.
                This will have also impact to hardware releated modules which hardcoded the /opt/vc/ path in their js code (e.g. mmm-systemtemperature).
                  sdetweil @karsten13
                  @karsten13 yes, movent towards the normal core will break older stuff…
                  wondering what is wrong w install
                    bert269 @BKeyport
                    @bkeyport - Config changes were already present in the older version(1.6.2) - just have to be invoked by pressing Alt-Shift-Z or X - cannot remember)
                    • rejasR Offline
                      rejas Module Developer
                      I am currently trying to update the docs with minimal infos on configuring on a fresh isntall.
                      So I took the 64 bit image as well, seems fine so far.
                      Only thing I am not trying to get working is rotating the display.
                      display_rotate=1
                      added to boot/config doesnt seem to work anymore. Anyone got it working?
                        sdetweil @rejas
                        @rejas did u try the display config in prefences?
                        rejasR 1 Reply Last reply Reply Quote 0
                        • rejasR Offline
                          rejas Module Developer @sdetweil
                          @sdetweil in raspi-config? or do you mean in the window manager? I was hoping of setting that via console
                            karsten13 @rejas
                            @rejas
                            it works in the WebUI preferences -> screen configuration
                            command line: xrandr --output HDMI-1 --rotate right (got it not working over ssh)
                            karsten13K S 2 Replies Last reply Reply Quote 0
                              If you use the WebUI the changes are made here:
                              pi@pi4:~ $ cat /usr/share/dispsetup.sh
                              #!/bin/sh
                              if ! grep -q 'Raspberry Pi' /proc/device-tree/model || (grep -q okay /proc/device-tree/soc/v3d@7ec00000/status 2> /dev/null || grep -q okay /proc/device-tree/soc/firmwarekms@7e600000/status 2> /dev/null || grep -q okay /proc/device-tree/v3dbus/v3d@7ec04000/status 2> /dev/null) ; then
                              if xrandr --output HDMI-1 --primary --mode 1920x1080 --rate 60.000 --pos 0x0 --rotate normal --output HDMI-2 --off --dryrun ; then
                              fi
                              fi
                              if [ -e /usr/share/tssetup.sh ] ; then
                              . /usr/share/tssetup.sh
                              fi
                              exit 0
                              So editing this script should work for command line.
                              rejasR 1 Reply Last reply Reply Quote 1
                                sdetweil @karsten13
                                @karsten13 cool. once u know what it does, easy
                                • rejasR Offline
                                  rejas Module Developer @karsten13
                                  @karsten13 thanks for the info. so i guess for the docs page it will be a “do it via the ui” info instead of the good old “edit this file” :-)
