Unsolved MMM-MyWastePickup date problem
Anyone, any idea?
Who else uses MyWastePickup with Bullseye/MM2.18?BR
Jens -
@mymirror you are on the wrong node version
need 14 or preferably 16
the steps outlined here might help
https://github.com/MichMich/MagicMirror/issues/2772my mm install script does that as part of mm install
Hi Sam,i’ve downgraded node but without success. MMM-MyWastePickup is still “Loading”
pi@MM3:~ $ node -v v16.13.2 pi@MM3:~ $ npm -v 8.1.2
The content (test entries) of my schedule_custom.csv:
Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree Custom,02/07/22,0,1,0,0,0 Custom,02/08/22,0,0,1,0,0 Custom,03/02/22,0,1,0,0,0 Custom,03/09/22,0,1,0,0,0 Custom,03/10/22,1,0,0,0,0
Aus der Config.js:
{ module: "MMM-MyWastePickup", position: "top_center", // header: "Müllabfuhr", header: "WASTE", config: { collectionCalendar: "Custom", weeksToDisplay: "2" } },
pm2 log:
pi@MM3:~/MagicMirror $ pm2 log [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option) /home/pi/.pm2/pm2.log last 15 lines: PM2 | 2022-02-06T22:00:22: PM2 log: PM2 version : 5.1.2 PM2 | 2022-02-06T22:00:22: PM2 log: Node.js version : 17.4.0 PM2 | 2022-02-06T22:00:22: PM2 log: Current arch : arm PM2 | 2022-02-06T22:00:22: PM2 log: PM2 home : /home/pi/.pm2 PM2 | 2022-02-06T22:00:22: PM2 log: PM2 PID file : /home/pi/.pm2/pm2.pid PM2 | 2022-02-06T22:00:22: PM2 log: RPC socket file : /home/pi/.pm2/rpc.sock PM2 | 2022-02-06T22:00:22: PM2 log: BUS socket file : /home/pi/.pm2/pub.sock PM2 | 2022-02-06T22:00:22: PM2 log: Application log path : /home/pi/.pm2/logs PM2 | 2022-02-06T22:00:22: PM2 log: Worker Interval : 30000 PM2 | 2022-02-06T22:00:22: PM2 log: Process dump file : /home/pi/.pm2/dump.pm2 PM2 | 2022-02-06T22:00:22: PM2 log: Concurrent actions : 2 PM2 | 2022-02-06T22:00:22: PM2 log: SIGTERM timeout : 1600 PM2 | 2022-02-06T22:00:22: PM2 log: =============================================================================== PM2 | 2022-02-06T22:00:22: PM2 log: App [mm:0] starting in -fork mode- PM2 | 2022-02-06T22:00:22: PM2 log: App [mm:0] online /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines: 0|mm | at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9 0|mm | at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read_file_context:68:3) 0|mm | [06.02.2022 21:37.41.484] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [06.02.2022 21:37.41.485] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues 0|mm | [1468:0100/000000.525475:ERROR:connection.cc(66)] X connection error received. 0|mm | [07.02.2022 06:05.42.345] [WARN] The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path 0|mm | [1440:0207/060546.132881:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization 0|mm | [1483:0207/060547.287531:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization 0|mm | [1502:0207/060550.327609:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process. 0|mm | [07.02.2022 06:05.57.254] [ERROR] Whoops! There was an uncaught exception... 0|mm | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function 0|mm | at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9 0|mm | at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read_file_context:68:3) 0|mm | [07.02.2022 06:05.57.266] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? 0|mm | [07.02.2022 06:05.57.267] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines: 0|mm | [07.02.2022 06:05.42.349] [LOG] Starting node helper for: newsfeed 0|mm | [07.02.2022 06:05.42.350] [LOG] Sockets connected & modules started ... 0|mm | [07.02.2022 06:05.43.840] [LOG] Launching application. 0|mm | [07.02.2022 06:05.56.764] [LOG] Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 0|mm | [07.02.2022 06:05.56.895] [INFO] Checking git for module: MMM-MyWastePickup 0|mm | [07.02.2022 06:05.57.216] [INFO] Checking git for module: MMM-Fuel 0|mm | [07.02.2022 06:05.57.294] [INFO] Checking git for module: MMM-OpenWeather24Hours 0|mm | [07.02.2022 06:05.57.357] [INFO] Checking git for module: default 0|mm | [07.02.2022 06:05.58.648] [INFO] Newsfeed-Fetcher: Broadcasting 61 items. 0|mm | [07.02.2022 06:10.59.278] [INFO] Newsfeed-Fetcher: Broadcasting 62 items. 0|mm | [07.02.2022 06:15.59.864] [INFO] Newsfeed-Fetcher: Broadcasting 62 items. 0|mm | [07.02.2022 06:21.00.369] [INFO] Newsfeed-Fetcher: Broadcasting 62 items. 0|mm | [07.02.2022 06:26.00.875] [INFO] Newsfeed-Fetcher: Broadcasting 62 items.
BR
Jens -
And the output of your script (test run):
pi@MM3:~/MagicMirror $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" No LSB modules are available. doing test run = true, NO updates will be applied! update log will be in /home/pi/MagicMirror/installers/upgrade.log Check current Node installation ... Node currently installed. Checking version number. Minimum Node version: v16.9.1 Installed Node version: v16.13.2 No Node.js upgrade necessary. Check current NPM installation ... NPM currently installed. Checking version number. Minimum npm version: V7.11.2 Installed npm version: V8.1.2 No npm upgrade necessary. saving custom.css upgrading from version 2.18.0 to 2.18.0 fetching latest revisions there are 2 local files that are different than the master repo installers/mm.sh package.json do you want to save these files for later (Y/n)? Checking for modules with removed libraries require for request in module MMM-SystemStats not found in package.json package.json for module MMM-SystemStats bypass installing request for module MMM-SystemStats , doing test run processing dependency changes for active modules with package.json files processing for module MMM-MyWastePickup please wait ---------------------------------- skipped processing for MMM-MyWastePickup, doing test run processing complete for module MMM-MyWastePickup processing for module MMM-Fuel please wait ---------------------------------- skipped processing for MMM-Fuel, doing test run processing complete for module MMM-Fuel restoring custom.css test run, restoring files stashed pi@MM3:~/MagicMirror $
@mymirror said in MMM-MyWastePickup date problem:
! There was an uncaught exception…
0|mm | at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9the module is having a problem, I would report that to the module GitHub page
@bravooscar said in MMM-MyWastePickup date problem:
MMM-MyWastePickup
Make sure that you only have one (1) empty line after the last in the schedule_custom.csv. If you have more empty lines it will break.
@mickecarlsson
Thanks for your hint.i actually had 2 blank lines at the end of the list.
But nothing changed, no matter if there were 2, 1 or no blank lines at the end of the list (not even after a restart of the MM or of the whole Pi.Jens
Hi there,
I recently installed this module and found no problems.
Hereby a screenshot from the last lines in the csv file.and a screenshot to show you that it works;
Best regards,
John -
@johndb
?? Without “Custom” in the beginning of every line?As described here https://github.com/jclarke0000/MMM-MyWastePickup, however, it should look like this:
Custom,03/07/18,1,0,1,0,0
Custom,03/14/18,1,1,1,0,0
Custom,03/21/18,1,0,1,0,0
Custom,03/28/18,1,1,1,0,0And then there is the error message (see above).
I have the version 2.18 of the MM running under Bullseye. -
@all
Who can help?
I think the problem is here:! There was an uncaught exception… 0|mm | [07.02.2022 06:05.57.264] [ERROR] TypeError: parse is not a function 0|mm | at /home/pi/MagicMirror/modules/MMM-MyWastePickup/node_helper.js:36:9
Jens
