    Centering Photos on MMM-ImagesPhotos
    11 Posts 3 Posters 3.5k Views 3 Watching
    • K Offline
      kit444
      I’m trying to use this in the fullscreen_below position. The photos will not center on the screen. Is there a way to do this, or to use the “contain” or “cover” options like on MMM-BackgroundSlideshow?
        sdetweil @kit444
        @kit444 I don’t like the way cover and contain work
        I have my own version that does centering and fill around
        https://github.com/sdetweil/MMM-ImagesPhotos
        • K Offline
          kit444
          @sdetweil I’m trying your version and I’m still having issues with the photos not centering. Here is the code I’m using in the config file.
          			module: "MMM-ImagesPhotos",
          			position: "fullscreen_below",
          				opacity: 1.0,
          				animationSpeed: 500,
          				updateInterval: 5000,
          				backgroundColor: 'grey',
          				//backgroundSize:'contain',  // not used if fill is true
          				fill: true,   // fill around image with blurred copy of image
          				blur: 10, // only used if fill is true
          				//maxWidth: 1920,
          				//maxHeight: 1080,
          • plainbrokeP Offline
            plainbroke @kit444
            @kit444
            I use this in the custom.css to center mine:
            .MMM-ImagesPhotos {
            Horizontal-align: center;
            Vertical-align: middle;
            My Config.js :
            module: “MMM-ImagesPhotos”,
            position: “middle_center”,
            opacity: 0.9,
            updateInterval: 10000,
            backgroundColor: “black”,
            width: “800px”,
            height: “800px”,
            fill: false
            Works for the screen I use. it did’nt untill I set the width and height though.
            Just my 2 cents. Mileage may vary for you though.
            K S 2 Replies Last reply Reply Quote 0
            • K Offline
              kit444 @plainbroke
              @plainbroke Unfortunately if I use the middle_center position, the photos will block out the other modules on the page. I need to use the fullscreen_below region. I tried to add the Horizontal-align to my css, but it didn’t recognize that parameter.
                sdetweil @plainbroke
                @plainbroke weird. the code reads the screen height and width and adjusts the position and size to keep the same aspect ratio.
                also, the background is already black
                only on my version. the original does it differently
                  sdetweil @kit444
                  @kit444 you could add a css z-index:-1
                  but that is what background does.
                  • K Offline
                    kit444 @sdetweil
                    @sdetweil I could use that code to position the middle_center region behind the other regions?
                      sdetweil @kit444
                      @kit444 z-index:-?? just pushes it farther away, other modules would then be on top z-index:0;
                      fullscreen-above is z-index:1;
                      • K Offline
                        kit444 @sdetweil
                        @sdetweil I’m still not having any luck. I tried adding z-index: -1 to the region.middle_center in the custom css. It still placed the photos over some of the modules. I tried adding a z-index: 0 or 1 to another region to see if I could re-layer the regions. No difference. I added z-index: -1 to the middle_center region in the main. css. It centered the photos under all the other regions, but left a black bar in the middle of each. Lastly I tried to add an align-items and align-content to the main css under the fullscreen region. Neither worked.
