    Centering Photos on MMM-ImagesPhotos
    11 Posts 3 Posters 3.2k Views 3 Watching
      sdetweil @plainbroke
      @plainbroke weird. the code reads the screen height and width and adjusts the position and size to keep the same aspect ratio.
      also, the background is already black
      only on my version. the original does it differently
        sdetweil @kit444
        @kit444 you could add a css z-index:-1
        but that is what background does.
        • K Offline
          kit444 @sdetweil
          @sdetweil I could use that code to position the middle_center region behind the other regions?
            sdetweil @kit444
            @kit444 z-index:-?? just pushes it farther away, other modules would then be on top z-index:0;
            fullscreen-above is z-index:1;
            • K Offline
              kit444 @sdetweil
              @sdetweil I’m still not having any luck. I tried adding z-index: -1 to the region.middle_center in the custom css. It still placed the photos over some of the modules. I tried adding a z-index: 0 or 1 to another region to see if I could re-layer the regions. No difference. I added z-index: -1 to the middle_center region in the main. css. It centered the photos under all the other regions, but left a black bar in the middle of each. Lastly I tried to add an align-items and align-content to the main css under the fullscreen region. Neither worked.
                sdetweil @kit444
                @kit444 rather than try and try and try
                see
                https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1644962684132
                one thing to do to learn the regions is to set each to a different background color.
                the regions overlap…
