    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 247.5k Views 39 Watching
    • JalibuJ
      Jalibu Module Developer @Jo 0
      @jo-0 in the modules/MMM-Jast folder try to execute git reset --hard first and continue with git pull and npm install --only=production in a second step.
      J 1 Reply Last reply
        Jo 0 @Jalibu
        @jalibu
        thank you very much, that was the solution
          requiemmg
          Just noticed that I get this message on MM startup. Everything is running, current update installed this morning.
          0|MagicMirror  | [26.01.2022 11:04.50.818] [ERROR]
          0|MagicMirror  | ERROR! Could not validate main module js file.
          0|MagicMirror  | [26.01.2022 11:04.50.839] [ERROR]
          0|MagicMirror  | ReferenceError: Log is not defined
          0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:4347)
          0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
          0|MagicMirror  |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
          0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:988:32)
          0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:829:12)
          0|MagicMirror  |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
          0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1012:19)
          0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:94:18)
          0|MagicMirror  |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
          0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
          0|MagicMirror  | [2805:0126/110450.830713:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          JalibuJ 1 Reply Last reply
          • JalibuJ
            Jalibu Module Developer @requiemmg
            @requiemmg whats your MagicMirror version?
            karsten13K 1 Reply Last reply
            • karsten13K
              karsten13 @Jalibu
              @jalibu
              I have similar errors running MMM-RAIN-MAP, happens only when using electron (not in server only). Using current mm develop branch.
              • JalibuJ
                Jalibu Module Developer @karsten13
                thx @karsten13, I’ll check that for both modules
                • JalibuJ
                  Hi @karsten13 @requiemmg,
                  this is a MMM-Remote-Control Bug: https://github.com/Jopyth/MMM-Remote-Control/issues/267
                  R 1 Reply Last reply
                    requiemmg @Jalibu
                    Thanks for the update. So I just ignore it and wait for fix.
                      MMuser
                      Hi, i am struggling with your module. I am testing MM in VM on Ubuntu. It seems that module is running but i still see only Loading instead of content. I ve tried default config provided on Git and also some config from this feed with no succes.
                      • JalibuJ
                        Jalibu Module Developer @MMuser
                        @mmuser did you install the dependencies using npm install?
                          MMuser
                          Hi, yes i installed everything and after few restarts it is finally working, you did indeed great job, thanks for this module.
                          Maybe one quick question, for horizontal scrolling, on the left side, scrolling is aligned with module above but on right side, scrolling starting on very right side ( don’t know how to insert screenshot to this forum). I tried to modify maxWidth -no result, as it is according to description related only to vertical style. Any possibility to correct this ?
                          • O
                            Overbid4225
                            Was anyone able to make this work for Australia?
                            I have tried AS and ASX both dont work. Example BOQ.AS but works on Yahoo Finance
                            • JalibuJ
                              Jalibu Module Developer @Overbid4225
                              @Overbid4225 please check your logs: API request for BOQ.AS failed: Quote not found for ticker symbol: BOQ.AS
                              This message does not come from the MMM-Jast module, but from the Yahoo Finance library. Apparently a required value is not available for this symbol.
                              Since MMM-Jast depends on the results of the Yahoo Finance Library, unfortunately I can’t help you here either.
                              O 1 Reply Last reply
                              • O
                                Overbid4225 @Jalibu
                                @Jalibu I see, thanks for the reply. Strange on Yahoo’s part to resolve BOQ.AS on their website or any other asx for that matter but not allow on API. https://finance.yahoo.com/quote/BOQ.AX?p=BOQ.AX&.tsrc=fin-srch
                                • JalibuJ
                                  @Overbid4225 yap, that‘s strange. The Yahoo Finanance library is unofficial and does not use a public API. Instead it just parses the Yahoo Website ;-)
                                  D 1 Reply Last reply
                                    Dracarys @Jalibu
                                    @Jalibu Hi, for me the module just stopped working since yesterday. It only says ‘loading’. Restartig the mirror doesnt Help. Before that it worked flawlessly for months. Is it Just me or does anyone else have this problem too?
                                    • JalibuJ
                                      Jalibu Module Developer @Dracarys
                                      @Dracarys It still works for me without any problems.
                                      Do you get any logs?
                                        Dracarys
                                        I will post it as soon as i have the time :)
                                        EDIT:
                                        [30.06.2022 01:07.44.449] [ERROR] There was an error requesting the API. Failed Yahoo Schema validation
                                        • JalibuJ
                                          @Dracarys
                                          That’s strange. Can you sort out which symbol causes this error?
                                          If it makes you happy, right now it’s better to see an error message on the mirror than to be shown the current stock performance.
                                          Reply Quote 2
                                            Dracarys
                                            i just got rid of all smybols and used BMW.DE Its still the same unfortunately. I even updated on the last version of jast but that also didnt help.
                                            • 6 / 9
