    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 237.7k Views 39 Watching
      Jo 0 @Jalibu
      @jalibu don’t know how to PN
      therefore here:
      module: “MMM-Jast”,
      position: “bottom_right”, //“bottom_center”,
      locale: “de-DE”,
      useGrouping: true,
      stocks: [
      { name: “DOW 30”, symbol: “^DJI”, quantity: 10 },
      //{ name: “S&P 500”, symbol: “^GSPC”, quantity: 15 },
      { name: “Nasdaq 100”, symbol: “^NDX” },
      //{ name: “DAX 30”, symbol: “^GDAXI” },
      { name: “EUR/USD”, symbol: “EURUSD=X”}
      maxWidth: “100%”,
      updateIntervalInSeconds: 300,
      fadeSpeedInSeconds: 15, //3.5,
      scroll: “none”, // One of [“none”, “vertical”, “horizontal”]
      useGrouping: false,
      currencyStyle: “symbol”, // One of [“code”, “symbol”, “name”]
      lastUpdateFormat: “HH:mm”,
      showColors: true,
      showCurrency: true,
      showChangePercent: true,
      showChangeValue: false,
      showChangeValueCurrency: false,
      showLastUpdate: false,
      showPortfolioValue: false,
      showPortfolioGrowthPercent: false,
      showPortfolioGrowth: false,
      numberDecimalsValues: 2,
      numberDecimalsPercentages: 1,
      virtualHorizontalMultiplier: 2
      S JalibuJ 2 Replies Last reply Reply Quote 0
        sdetweil @Jo 0
        @jo-0 he meant pm, private message
          Jo 0 @sdetweil
          @sdetweil I know, but where can I find the email address?
            sdetweil @Jo 0
            @jo-0 not email. chat here,
            click his username,
            then 3 dots to the right,
            start new chat
            • JalibuJ Offline
              Jalibu Module Developer @Jo 0
              @jo-0 you have useGrouping property twice in your settings. As true and as false. remove the ‚useGrouping: false‘ and it will work
                Jo 0 @Jalibu
                @jalibu Hi,
                workes fine now! Exactly how i wanted it.
                thank you.
                But next:
                how can I update the modul?
                ‘git pull’
                decline with the notice ‘please committen or stashen …’
                cancellation.
                Not sure what to do.
                JalibuJ 1 Reply Last reply Reply Quote 0
                • JalibuJ Offline
                  @jo-0 in the modules/MMM-Jast folder try to execute git reset --hard first and continue with git pull and npm install --only=production in a second step.
                    Jo 0 @Jalibu
                    @jalibu
                    thank you very much, that was the solution
                      requiemmg
                      Just noticed that I get this message on MM startup. Everything is running, current update installed this morning.
                      0|MagicMirror  | [26.01.2022 11:04.50.818] [ERROR]
                      0|MagicMirror  | ERROR! Could not validate main module js file.
                      0|MagicMirror  | [26.01.2022 11:04.50.839] [ERROR]
                      0|MagicMirror  | ReferenceError: Log is not defined
                      0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:4347)
                      0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                      0|MagicMirror  |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                      0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:988:32)
                      0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:829:12)
                      0|MagicMirror  |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                      0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                      0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:94:18)
                      0|MagicMirror  |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                      0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                      0|MagicMirror  | [2805:0126/110450.830713:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                      • JalibuJ Offline
                        Jalibu Module Developer @requiemmg
                        @requiemmg whats your MagicMirror version?
                        • karsten13K Offline
                          karsten13 @Jalibu
                          @jalibu
                          I have similar errors running MMM-RAIN-MAP, happens only when using electron (not in server only). Using current mm develop branch.
                          • JalibuJ Offline
                            Jalibu Module Developer @karsten13
                            thx @karsten13, I’ll check that for both modules
                            • JalibuJ Offline
                              Hi @karsten13 @requiemmg,
                              this is a MMM-Remote-Control Bug: https://github.com/Jopyth/MMM-Remote-Control/issues/267
                                requiemmg @Jalibu
                                Thanks for the update. So I just ignore it and wait for fix.
                                  MMuser
                                  Hi, i am struggling with your module. I am testing MM in VM on Ubuntu. It seems that module is running but i still see only Loading instead of content. I ve tried default config provided on Git and also some config from this feed with no succes.
                                  • JalibuJ Offline
                                    Jalibu Module Developer @MMuser
                                    @mmuser did you install the dependencies using npm install?
                                      MMuser
                                      Hi, yes i installed everything and after few restarts it is finally working, you did indeed great job, thanks for this module.
                                      Maybe one quick question, for horizontal scrolling, on the left side, scrolling is aligned with module above but on right side, scrolling starting on very right side ( don’t know how to insert screenshot to this forum). I tried to modify maxWidth -no result, as it is according to description related only to vertical style. Any possibility to correct this ?
                                      • O Offline
                                        Overbid4225
                                        Was anyone able to make this work for Australia?
                                        I have tried AS and ASX both dont work. Example BOQ.AS but works on Yahoo Finance
                                        • JalibuJ Offline
                                          Jalibu Module Developer @Overbid4225
                                          @Overbid4225 please check your logs: API request for BOQ.AS failed: Quote not found for ticker symbol: BOQ.AS
                                          This message does not come from the MMM-Jast module, but from the Yahoo Finance library. Apparently a required value is not available for this symbol.
                                          Since MMM-Jast depends on the results of the Yahoo Finance Library, unfortunately I can’t help you here either.
                                          • O Offline
                                            Overbid4225 @Jalibu
                                            @Jalibu I see, thanks for the reply. Strange on Yahoo’s part to resolve BOQ.AS on their website or any other asx for that matter but not allow on API. https://finance.yahoo.com/quote/BOQ.AX?p=BOQ.AX&.tsrc=fin-srch
                                            • 6 / 9
