    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 243.5k Views 39 Watching
      Jo 0 @Jalibu
      @jalibu thanks for fast answering,
      Doesn’t work the way I want it to.
      I just want the separator for the thousands.
      modules locale: “de-DE”,
      Jast lokale:
      de-DE gives 14170,85$
      en-GB gives US$14170.85
      What I want is 14.170,85$
      JalibuJ 1 Reply Last reply Reply Quote 0
      • JalibuJ
        Jalibu Module Developer @Jo 0
        @jo-0 add
        useGrouping: true,
        to your module configuration.
          Jo 0 @Jalibu
          @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
          useGrouping: true,
          it does not work.
          I run scroll: “none”
          J JalibuJ 2 Replies Last reply Reply Quote 0
            Jo 0 @Jo 0
            @jo-0
            Btw. I’m new in MMM.
            I got the message that there is an update for JaST.
            How can I get this
            git pull
            npm install --only=production
            does not help
              sdetweil @Jo 0
              @jo-0 in the module folder, right?
              • JalibuJ
                @jo-0 said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
                useGrouping: true,
                it does not work.
                please PN me your module config
                  Jo 0 @Jalibu
                  @jalibu don’t know how to PN
                  therefore here:
                  module: “MMM-Jast”,
                  position: “bottom_right”, //“bottom_center”,
                  locale: “de-DE”,
                  useGrouping: true,
                  stocks: [
                  { name: “DOW 30”, symbol: “^DJI”, quantity: 10 },
                  //{ name: “S&P 500”, symbol: “^GSPC”, quantity: 15 },
                  { name: “Nasdaq 100”, symbol: “^NDX” },
                  //{ name: “DAX 30”, symbol: “^GDAXI” },
                  { name: “EUR/USD”, symbol: “EURUSD=X”}
                  maxWidth: “100%”,
                  updateIntervalInSeconds: 300,
                  fadeSpeedInSeconds: 15, //3.5,
                  scroll: “none”, // One of [“none”, “vertical”, “horizontal”]
                  useGrouping: false,
                  currencyStyle: “symbol”, // One of [“code”, “symbol”, “name”]
                  lastUpdateFormat: “HH:mm”,
                  showColors: true,
                  showCurrency: true,
                  showChangePercent: true,
                  showChangeValue: false,
                  showChangeValueCurrency: false,
                  showLastUpdate: false,
                  showPortfolioValue: false,
                  showPortfolioGrowthPercent: false,
                  showPortfolioGrowth: false,
                  numberDecimalsValues: 2,
                  numberDecimalsPercentages: 1,
                  virtualHorizontalMultiplier: 2
                  S JalibuJ 2 Replies Last reply Reply Quote 0
                    sdetweil @Jo 0
                    @jo-0 he meant pm, private message
                      Jo 0 @sdetweil
                      @sdetweil I know, but where can I find the email address?
                        sdetweil @Jo 0
                        @jo-0 not email. chat here,
                        click his username,
                        then 3 dots to the right,
                        start new chat
                        • JalibuJ
                          @jo-0 you have useGrouping property twice in your settings. As true and as false. remove the ‚useGrouping: false‘ and it will work
                            Jo 0 @Jalibu
                            @jalibu Hi,
                            workes fine now! Exactly how i wanted it.
                            thank you.
                            But next:
                            how can I update the modul?
                            ‘git pull’
                            decline with the notice ‘please committen or stashen …’
                            cancellation.
                            Not sure what to do.
                            • JalibuJ
                              @jo-0 in the modules/MMM-Jast folder try to execute git reset --hard first and continue with git pull and npm install --only=production in a second step.
                                Jo 0 @Jalibu
                                @jalibu
                                thank you very much, that was the solution
                                  requiemmg
                                  Just noticed that I get this message on MM startup. Everything is running, current update installed this morning.
                                  0|MagicMirror  | [26.01.2022 11:04.50.818] [ERROR]
                                  0|MagicMirror  | ERROR! Could not validate main module js file.
                                  0|MagicMirror  | [26.01.2022 11:04.50.839] [ERROR]
                                  0|MagicMirror  | ReferenceError: Log is not defined
                                  0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:4347)
                                  0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                                  0|MagicMirror  |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                                  0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:988:32)
                                  0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:829:12)
                                  0|MagicMirror  |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                                  0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                                  0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:94:18)
                                  0|MagicMirror  |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                                  0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                                  0|MagicMirror  | [2805:0126/110450.830713:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                  • JalibuJ
                                    Jalibu Module Developer @requiemmg
                                    @requiemmg whats your MagicMirror version?
                                    • karsten13K
                                      karsten13 @Jalibu
                                      @jalibu
                                      I have similar errors running MMM-RAIN-MAP, happens only when using electron (not in server only). Using current mm develop branch.
                                      • JalibuJ
                                        Jalibu Module Developer @karsten13
                                        thx @karsten13, I’ll check that for both modules
                                        • JalibuJ
                                          Hi @karsten13 @requiemmg,
                                          this is a MMM-Remote-Control Bug: https://github.com/Jopyth/MMM-Remote-Control/issues/267
                                            requiemmg @Jalibu
                                            Thanks for the update. So I just ignore it and wait for fix.
                                            • 5 / 9
