    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 238.4k Views 39 Watching
      Jo 0 @Jo 0
      @jo-0
      Btw. I’m new in MMM.
      I got the message that there is an update for JaST.
      How can I get this
      git pull
      npm install --only=production
      does not help
        sdetweil @Jo 0
        @jo-0 in the module folder, right?
        • JalibuJ Offline
          Jalibu Module Developer @Jo 0
          @jo-0 said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
          @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
          useGrouping: true,
          it does not work.
          I run scroll: “none”
          please PN me your module config
            Jo 0 @Jalibu
            @jalibu don’t know how to PN
            therefore here:
            module: “MMM-Jast”,
            position: “bottom_right”, //“bottom_center”,
            locale: “de-DE”,
            useGrouping: true,
            stocks: [
            { name: “DOW 30”, symbol: “^DJI”, quantity: 10 },
            //{ name: “S&P 500”, symbol: “^GSPC”, quantity: 15 },
            { name: “Nasdaq 100”, symbol: “^NDX” },
            //{ name: “DAX 30”, symbol: “^GDAXI” },
            { name: “EUR/USD”, symbol: “EURUSD=X”}
            maxWidth: “100%”,
            updateIntervalInSeconds: 300,
            fadeSpeedInSeconds: 15, //3.5,
            scroll: “none”, // One of [“none”, “vertical”, “horizontal”]
            useGrouping: false,
            currencyStyle: “symbol”, // One of [“code”, “symbol”, “name”]
            lastUpdateFormat: “HH:mm”,
            showColors: true,
            showCurrency: true,
            showChangePercent: true,
            showChangeValue: false,
            showChangeValueCurrency: false,
            showLastUpdate: false,
            showPortfolioValue: false,
            showPortfolioGrowthPercent: false,
            showPortfolioGrowth: false,
            numberDecimalsValues: 2,
            numberDecimalsPercentages: 1,
            virtualHorizontalMultiplier: 2
            S JalibuJ 2 Replies Last reply Reply Quote 0
              sdetweil @Jo 0
              @jo-0 he meant pm, private message
                Jo 0 @sdetweil
                @sdetweil I know, but where can I find the email address?
                  sdetweil @Jo 0
                  @jo-0 not email. chat here,
                  click his username,
                  then 3 dots to the right,
                  start new chat
                  • JalibuJ Offline
                    @jo-0 you have useGrouping property twice in your settings. As true and as false. remove the ‚useGrouping: false‘ and it will work
                      Jo 0 @Jalibu
                      @jalibu Hi,
                      workes fine now! Exactly how i wanted it.
                      thank you.
                      But next:
                      how can I update the modul?
                      ‘git pull’
                      decline with the notice ‘please committen or stashen …’
                      cancellation.
                      Not sure what to do.
                      JalibuJ 1 Reply Last reply Reply Quote 0
                      • JalibuJ Offline
                        @jo-0 in the modules/MMM-Jast folder try to execute git reset --hard first and continue with git pull and npm install --only=production in a second step.
                          Jo 0 @Jalibu
                          @jalibu
                          thank you very much, that was the solution
                            requiemmg
                            Just noticed that I get this message on MM startup. Everything is running, current update installed this morning.
                            0|MagicMirror  | [26.01.2022 11:04.50.818] [ERROR]
                            0|MagicMirror  | ERROR! Could not validate main module js file.
                            0|MagicMirror  | [26.01.2022 11:04.50.839] [ERROR]
                            0|MagicMirror  | ReferenceError: Log is not defined
                            0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:4347)
                            0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                            0|MagicMirror  |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                            0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:988:32)
                            0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:829:12)
                            0|MagicMirror  |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                            0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                            0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:94:18)
                            0|MagicMirror  |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                            0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                            0|MagicMirror  | [2805:0126/110450.830713:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                            • JalibuJ Offline
                              Jalibu Module Developer @requiemmg
                              @requiemmg whats your MagicMirror version?
                              • karsten13K Online
                                karsten13 @Jalibu
                                @jalibu
                                I have similar errors running MMM-RAIN-MAP, happens only when using electron (not in server only). Using current mm develop branch.
                                • JalibuJ Offline
                                  Jalibu Module Developer @karsten13
                                  thx @karsten13, I’ll check that for both modules
                                  • JalibuJ Offline
                                    Hi @karsten13 @requiemmg,
                                    this is a MMM-Remote-Control Bug: https://github.com/Jopyth/MMM-Remote-Control/issues/267
                                      requiemmg @Jalibu
                                      Thanks for the update. So I just ignore it and wait for fix.
                                        MMuser
                                        Hi, i am struggling with your module. I am testing MM in VM on Ubuntu. It seems that module is running but i still see only Loading instead of content. I ve tried default config provided on Git and also some config from this feed with no succes.
                                        • JalibuJ Offline
                                          Jalibu Module Developer @MMuser
                                          @mmuser did you install the dependencies using npm install?
                                            MMuser
                                            Hi, yes i installed everything and after few restarts it is finally working, you did indeed great job, thanks for this module.
                                            Maybe one quick question, for horizontal scrolling, on the left side, scrolling is aligned with module above but on right side, scrolling starting on very right side ( don’t know how to insert screenshot to this forum). I tried to modify maxWidth -no result, as it is according to description related only to vertical style. Any possibility to correct this ?
                                            • 5 / 9
