    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 243.5k Views 39 Watching
      MasonR1209
      Hey, I wanted to know if it’s possible to make a static always there Portfolio Value… that changes as the stocks listed change in price, but is always shown, and have the stocks ticker above / below the portfolio value, and not scroll to the portfolio value as it would be permanently shown… e.g
      Scrolling stocks ticker
      Portfolio Value: xxxx
      Possibly also add a static always shown portfolio change value / change percentage that isn’t included in the scroll.
      I would opt for the Static option for all as you can in the config but it takes up too much room on the mirror and I was wondering if what i’ve stated is configurable? Thanks
      ALSO. Having issues with the default module of ‘currentweather’. This MMM-Jast module makes my currentweather module disappear. It loads, then as soon as MMM-Jast loads, currentweather disappears. As soon as I remove MMM-Jast from the config, then currentweather works again.
      JalibuJ 1 Reply Last reply Reply Quote 0
      • JalibuJ
        Jalibu Module Developer @MasonR1209
        @masonr1209 please open two issues on GitHub on that. I’ll check them when I have more time again
          Jo 0
          how can I format the Output Numbers?
          like 34,265.37$ or
          34.265,37$ according the settings.
          • JalibuJ
            Jalibu Module Developer @Jo 0
            Hi @jo-0,
            MMM-JaST follows the formatting rules for your locale which is set in your config.js
            The comma as decimal separator is common for German locale for example (de-DE) where the dot as decimal separator is common for English locales (en-GB)
            var config = {
             language: "de",
             locale: "de-DE",
             timeFormat: 24,
             units: "metric",
             modules:
            Keep in mind that locale settings can affect all modules. MMM-JaST has an option to override global platform locale settings. Just add the following to your Jast module config:
                module: "MMM-Jast",
                 locale: "de-DE", // or any other desired locale for number formatting
              Jo 0 @Jalibu
              @jalibu thanks for fast answering,
              Doesn’t work the way I want it to.
              I just want the separator for the thousands.
              modules locale: “de-DE”,
              Jast lokale:
              de-DE gives 14170,85$
              en-GB gives US$14170.85
              What I want is 14.170,85$
              • JalibuJ
                @jo-0 add
                useGrouping: true,
                to your module configuration.
                  Jo 0 @Jalibu
                  @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
                  useGrouping: true,
                  it does not work.
                  I run scroll: “none”
                  J JalibuJ 2 Replies Last reply Reply Quote 0
                    Jo 0 @Jo 0
                    @jo-0
                    Btw. I’m new in MMM.
                    I got the message that there is an update for JaST.
                    How can I get this
                    git pull
                    npm install --only=production
                    does not help
                      sdetweil @Jo 0
                      @jo-0 in the module folder, right?
                      • JalibuJ
                        @jo-0 said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
                        useGrouping: true,
                        it does not work.
                        please PN me your module config
                          Jo 0 @Jalibu
                          @jalibu don’t know how to PN
                          therefore here:
                          module: “MMM-Jast”,
                          position: “bottom_right”, //“bottom_center”,
                          locale: “de-DE”,
                          useGrouping: true,
                          stocks: [
                          { name: “DOW 30”, symbol: “^DJI”, quantity: 10 },
                          //{ name: “S&P 500”, symbol: “^GSPC”, quantity: 15 },
                          { name: “Nasdaq 100”, symbol: “^NDX” },
                          //{ name: “DAX 30”, symbol: “^GDAXI” },
                          { name: “EUR/USD”, symbol: “EURUSD=X”}
                          maxWidth: “100%”,
                          updateIntervalInSeconds: 300,
                          fadeSpeedInSeconds: 15, //3.5,
                          scroll: “none”, // One of [“none”, “vertical”, “horizontal”]
                          useGrouping: false,
                          currencyStyle: “symbol”, // One of [“code”, “symbol”, “name”]
                          lastUpdateFormat: “HH:mm”,
                          showColors: true,
                          showCurrency: true,
                          showChangePercent: true,
                          showChangeValue: false,
                          showChangeValueCurrency: false,
                          showLastUpdate: false,
                          showPortfolioValue: false,
                          showPortfolioGrowthPercent: false,
                          showPortfolioGrowth: false,
                          numberDecimalsValues: 2,
                          numberDecimalsPercentages: 1,
                          virtualHorizontalMultiplier: 2
                          S JalibuJ 2 Replies Last reply Reply Quote 0
                            sdetweil @Jo 0
                            @jo-0 he meant pm, private message
                              Jo 0 @sdetweil
                              @sdetweil I know, but where can I find the email address?
                                sdetweil @Jo 0
                                @jo-0 not email. chat here,
                                click his username,
                                then 3 dots to the right,
                                start new chat
                                • JalibuJ
                                  @jo-0 you have useGrouping property twice in your settings. As true and as false. remove the ‚useGrouping: false‘ and it will work
                                    Jo 0 @Jalibu
                                    @jalibu Hi,
                                    workes fine now! Exactly how i wanted it.
                                    thank you.
                                    But next:
                                    how can I update the modul?
                                    ‘git pull’
                                    decline with the notice ‘please committen or stashen …’
                                    cancellation.
                                    Not sure what to do.
                                    • JalibuJ
                                      @jo-0 in the modules/MMM-Jast folder try to execute git reset --hard first and continue with git pull and npm install --only=production in a second step.
                                        Jo 0 @Jalibu
                                        @jalibu
                                        thank you very much, that was the solution
                                          requiemmg
                                          Just noticed that I get this message on MM startup. Everything is running, current update installed this morning.
                                          0|MagicMirror  | [26.01.2022 11:04.50.818] [ERROR]
                                          0|MagicMirror  | ERROR! Could not validate main module js file.
                                          0|MagicMirror  | [26.01.2022 11:04.50.839] [ERROR]
                                          0|MagicMirror  | ReferenceError: Log is not defined
                                          0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:4347)
                                          0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                                          0|MagicMirror  |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                                          0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:988:32)
                                          0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:829:12)
                                          0|MagicMirror  |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                                          0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                                          0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:94:18)
                                          0|MagicMirror  |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
                                          0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
                                          0|MagicMirror  | [2805:0126/110450.830713:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                                          • JalibuJ
                                            Jalibu Module Developer @requiemmg
                                            @requiemmg whats your MagicMirror version?
                                            • 5 / 9
