    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 239.6k Views 39 Watching
    • uros76U
      uros76 @Jalibu
      @jalibu I am making a small MM project, based on rpi 3 and a small screen. This will be used by my friends who are occasionally trading with crypto and stocks.
      Rather than teaching them how to edit a list of monitored stocks in the config.js (which could lead to catastrophic failure) I would prefer them to edit an independent shared file with the list of stocks only. This way we avoid breaking the core MM system and have the flexibility to change the list of stocks daily if needed.
      I like the idea of autogenerating the config file. Will have a look into it if I can do it with python script. If you come up with some other solution let me know.
      Thanks again
      JalibuJ 1 Reply Last reply Reply Quote 0
      • JalibuJ
        Jalibu Module Developer @uros76
        @uros76 why don’t you use @sdetweil 's Config Edit Tool MMM-Config?
        MMM-Jast has full support for it.
        uros76U 1 Reply Last reply Reply Quote 1
        • uros76U
          uros76 @Jalibu
          @jalibu I completely forgot about this one. I will disable the rest and just allow Jast module to be editable. This could also work, thanks
            sdetweil @Jalibu
            @jalibu you could pull a json list of stocks from a file, like compliments does
            and do it on some timed cycle, hourly, daily.
            @uros76 one could also try using my MMM-Config module, which presents a form for config.js, where user could + to add, - to remove
            see
            https://github.com/sdetweil/MMM-Config
            then the user could change via their phone or ipad/laptop…
            • uros76U
              uros76 @sdetweil
              @sdetweil excellent, yes that’s what I am trying now. Thanks
                I submitted a PR for jast to improve the form for the stocks list
                  mweth
                  Great module and I think this is a simple request. I would like for the ticker to only change to red or green if the stock moves by more than 5%. In VerticalStockList.njk, I changed the code as follows (and added a “same” color in the CSS, but it did not do anything. Super bonus points if I can make a movement of more than 7% show an image.
                  {{ utils.getStockName(stock) }}: {% if utils.getStockChange(stock) > 3 %} {% set colorClass = “high” %} {% elif utils.getStockChange(stock) < 3 %} {% set colorClass = "low " %} {% else %} {% set colorClass = “same” %}
                    MasonR1209
                    Hey, I wanted to know if it’s possible to make a static always there Portfolio Value… that changes as the stocks listed change in price, but is always shown, and have the stocks ticker above / below the portfolio value, and not scroll to the portfolio value as it would be permanently shown… e.g
                    Scrolling stocks ticker
                    Portfolio Value: xxxx
                    Possibly also add a static always shown portfolio change value / change percentage that isn’t included in the scroll.
                    I would opt for the Static option for all as you can in the config but it takes up too much room on the mirror and I was wondering if what i’ve stated is configurable? Thanks
                    ALSO. Having issues with the default module of ‘currentweather’. This MMM-Jast module makes my currentweather module disappear. It loads, then as soon as MMM-Jast loads, currentweather disappears. As soon as I remove MMM-Jast from the config, then currentweather works again.
                    • JalibuJ
                      Jalibu Module Developer @MasonR1209
                      @masonr1209 please open two issues on GitHub on that. I’ll check them when I have more time again
                        Jo 0
                        how can I format the Output Numbers?
                        like 34,265.37$ or
                        34.265,37$ according the settings.
                        • JalibuJ
                          Jalibu Module Developer @Jo 0
                          Hi @jo-0,
                          MMM-JaST follows the formatting rules for your locale which is set in your config.js
                          The comma as decimal separator is common for German locale for example (de-DE) where the dot as decimal separator is common for English locales (en-GB)
                          var config = {
                           language: "de",
                           locale: "de-DE",
                           timeFormat: 24,
                           units: "metric",
                           modules:
                          Keep in mind that locale settings can affect all modules. MMM-JaST has an option to override global platform locale settings. Just add the following to your Jast module config:
                              module: "MMM-Jast",
                               locale: "de-DE", // or any other desired locale for number formatting
                            Jo 0 @Jalibu
                            @jalibu thanks for fast answering,
                            Doesn’t work the way I want it to.
                            I just want the separator for the thousands.
                            modules locale: “de-DE”,
                            Jast lokale:
                            de-DE gives 14170,85$
                            en-GB gives US$14170.85
                            What I want is 14.170,85$
                            • JalibuJ
                              @jo-0 add
                              useGrouping: true,
                              to your module configuration.
                                Jo 0 @Jalibu
                                @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
                                useGrouping: true,
                                it does not work.
                                I run scroll: “none”
                                J JalibuJ 2 Replies Last reply Reply Quote 0
                                  Jo 0 @Jo 0
                                  @jo-0
                                  Btw. I’m new in MMM.
                                  I got the message that there is an update for JaST.
                                  How can I get this
                                  git pull
                                  npm install --only=production
                                  does not help
                                    sdetweil @Jo 0
                                    @jo-0 in the module folder, right?
                                    • JalibuJ
                                      @jo-0 said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
                                      useGrouping: true,
                                      it does not work.
                                      please PN me your module config
                                        Jo 0 @Jalibu
                                        @jalibu don’t know how to PN
                                        therefore here:
                                        module: “MMM-Jast”,
                                        position: “bottom_right”, //“bottom_center”,
                                        locale: “de-DE”,
                                        useGrouping: true,
                                        stocks: [
                                        { name: “DOW 30”, symbol: “^DJI”, quantity: 10 },
                                        //{ name: “S&P 500”, symbol: “^GSPC”, quantity: 15 },
                                        { name: “Nasdaq 100”, symbol: “^NDX” },
                                        //{ name: “DAX 30”, symbol: “^GDAXI” },
                                        { name: “EUR/USD”, symbol: “EURUSD=X”}
                                        maxWidth: “100%”,
                                        updateIntervalInSeconds: 300,
                                        fadeSpeedInSeconds: 15, //3.5,
                                        scroll: “none”, // One of [“none”, “vertical”, “horizontal”]
                                        useGrouping: false,
                                        currencyStyle: “symbol”, // One of [“code”, “symbol”, “name”]
                                        lastUpdateFormat: “HH:mm”,
                                        showColors: true,
                                        showCurrency: true,
                                        showChangePercent: true,
                                        showChangeValue: false,
                                        showChangeValueCurrency: false,
                                        showLastUpdate: false,
                                        showPortfolioValue: false,
                                        showPortfolioGrowthPercent: false,
                                        showPortfolioGrowth: false,
                                        numberDecimalsValues: 2,
                                        numberDecimalsPercentages: 1,
                                        virtualHorizontalMultiplier: 2
                                        S JalibuJ 2 Replies Last reply Reply Quote 0
                                          sdetweil @Jo 0
                                          @jo-0 he meant pm, private message
                                            Jo 0 @sdetweil
                                            @sdetweil I know, but where can I find the email address?
                                            • 5 / 9
