    Having issues with pm2
    7 Posts 2 Posters 971 Views 2 Watching
    • delta 1D Offline
      delta 1
      Node_modules/ .bin/electron: not found
      S delta 1D 2 Replies Last reply Reply Quote 0
        sdetweil @delta 1
        @delta-1 what pi?
        how did u install mm?
        • delta 1D Offline
          delta 1 @delta 1
          @delta-1
          • delta 1D Offline
            delta 1 @sdetweil
            I’m using a pie 3 module B v1.2
            • delta 1D Offline
              delta 1 @sdetweil
              I’m following the steps on the magic mirror central website
                sdetweil @delta 1
                @delta-1 when did u build the SD card?
                show results of
                uname -a
                node -v
                npm -v
                lsb_release - a
                maybe try the automated scripts, from a fresh flash ( the newer ones are picky if they get trouble)
                see
                delta 1D 1 Reply Last reply Reply Quote 0
                • delta 1D Offline
                  delta 1 @sdetweil
                  Ok thanks much I’ll try
