    Two modules side by side
    14 Posts 4 Posters 3.9k Views 3 Watching
      MMuser
      Hello, i’d like to position two modules side by side. When i specific same position (for example bottom-left) for two modules, second one is positioned under first one. is it possible to position second module on the right of first one, not using new position bottom-center.
        sdetweil @MMuser
        @mmuser you will have to use CSS for that
          MMuser
          @sdetweil any suggestion ? i have no experience with css, i was able to change text size and alignment and this is max what i am capable of.
            [[global:former-user]]
              MMuser
              @hango thank you so much for reply, this is working very good with two different modules, issue is that i have same module in config.js more then once ( reason is that module can show info only from one bus stop and i want more), is it possible to identify instances (something like .first_module_1, .first_module_2) of one module and apply your advice ?
              ? mumblebajM 2 Replies Last reply Reply Quote 0
                [[global:former-user]] @MMuser
                • mumblebajM Offline
                  mumblebaj Module Developer @MMuser
                  @mmuser I would suggest that you grab the module_id from the Developer Window|Elements Tab. then use the div id for the module and assign the CSS as per @hango using the div id. If I had 2 instances of MMM-SweepClock in my config it would be assigned module_0_MMM-SweepClock and module_1_MMM-SweepClock
                  ? 1 Reply Last reply Reply Quote 1
                    [[global:former-user]] @mumblebaj
                      mumblebaj Module Developer @Guest
                      @hango Yeah, got you. Just thought it easier to get the div id rather than adding a class to config.
                        S mumblebajM 2 Replies Last reply Reply Quote 0
                          sdetweil @Guest
                          @hango thank you SO much.
                          if you give them the answer they will never learn.
                          teach them how to solve the problem.
                            [[global:former-user]] @sdetweil
                              MMuser
                              code with classes works well, i have some coding basics from school ( C and C++), no experience with CSS, but i m trying to learn as much as possible, currently running MM on Raspbian in VM and also on Win, want to tweak MM to final version before buying Raspi ( what is currently not available anywhere in my country)
                                @hango Wow, interesting stance you have, I thought this is a learning forum not a feeding scheme. Maybe I will just others who have with replies like these not participated or helped other in need anymore. Go for GOLD @hango
