    display issue MMM-PublicTransportHafas
    11 Posts 2 Posters 5.5k Views 2 Watching
      Jo 0 @KristjanESPERANTO
      @kristjanesperanto
      Okay, thanks for the hint. I changed it and will keep an eye on it.
        Jo 0 @Jo 0
        @jo-0
        Hello, I’ve been watching it for 24 hours now and it seems to be working. No more wrong output. Thank you again for the useful tip.
          @kristjanesperanto
          Pity, the double output at has disappeared, but the same problem now occurs at in the direction of ‘Kleinzschachwitz’.
          region Dresden Postplatz
          stationID: “975242”
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @Jo 0
            @jo-0 Okay, I still think that there is something non-standard with the data from the transport company, but we can investigate this further. Can you try the configuration ignoreRelatedStations: true, in combination with both stationIDs?
              @kristjanesperanto said in display issue MMM-PublicTransportHafas:
              Thanks.
              I added it to the config and will monitor the behavior. First with stationID: “975242”,
                Jo 0 @Jo 0
                @jo-0
                short feedback:
                with “ID: 975247” only , and are displayed.
                “ID: 975242” only the others, but the above are missing.
                A double display no longer occurred.
                  Jo 0 @Jo 0
                  @jo-0 short feedback:
                  sorry for typo.
                  with “ID: 975247” only STR1, STR2 and STR4 are displayed.
                    I now have no idea how we can solve this properly. Would it perhaps be a solution for you to integrate the module twice, with the two different IDs?
                      @kristjanesperanto
                      Since the update last week the module is running fine. No more duplicate lines. I think this is the right way.
                      Run now with stationID: “975242” and and comment //ignoreRelatedStations: true again.
                      Btw.
                      I have no space to display the module twice on the display.
