    Multiple Vehicles MMM-BMWConnected
    10 Posts 3 Posters 2.6k Views 3 Watching
      crush @mumblebaj
      @mumblebaj I tried that, unfortunately unsuccessfully.
      My two problems:
      1. Instance 2 shows the same values ​​as instance 1, although I use different access data for Instance 2.
      2. The image isn’t displayed correctly, it seems like everything is a bit bigger and so it doesn’t fit properly anymore.
        I am attaching a picture.
      • strawberry 3.141S Offline
        @crush the module doesn’t support multiple instances by itself.
        By the design of the MagicMirror framework, all instances of the module share one node_helper, which in the case of this module is overwriting the config.
        You could ask the author in the Github repo for multi-instance support.
        There is also a workaround to achieve this, until the module provides multi-instance support out of the box, by duplicating the module directory and renaming it to MMM-BMWConnected2. Inside that directory, you have to rename files like MMM-BMWConnected.js to MMM-BMWConnected2.js. Also inside the files, you have to change all occurrences from MMM-BMWConnected to MMM-BMWConnected. Don’t forget to change the module name in the config.js for your second entry. You should repeat this process after every update of the module that you install to stay up-to-date.
          crush @strawberry 3.141
          @strawberry-3-141 Thank you for your response. I used this workaround by duplicating before (yesterday) and had the problems as mentioned. The second instance (www-bmwconnected2) shows the same datas as instance number one (www-bmwconnected)???
          • mumblebajM Offline
            mumblebaj Module Developer @crush
            @crush and @strawberry-3-141 could it be that both the modules are getting the same notification and payload?
              @crush are you sure you also changed the module name for the second instance in the config file? It sounds like you have forgotten to rename something. If you need more help you can contact me on the discord channel and I can have a look.
              @mumblebaj the notifications are bidirectional with the node_helper, after renaming the module correctly MagicMirror will spawn a node_helper A for module A and node_helper B for module B. They communicate directly with each other (sendSocketNotification) so the other module will not receive the notification.
              C 2 Replies Last reply Reply Quote 0
                  @strawberry-3-141 I got it, thanks. I had to rename both modules like “module1” and “module2”. “Module” only and “Module2” as second didn’t work!
                    strawberry 3.141 Project Sponsor Module Developer @crush
                    @crush that shouldn’t matter. Maybe you forgot to rename something that you fixed with renaming again.
