    MMM-OneCallWeather
    24 Posts 2 Posters 8.5k Views 2 Watching
    • N6NGN Offline
      N6NG
      Thank you Sam
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir | [23.02.2022 10:19.19.438] [ERROR] Whoops! There was an uncaught exception…
      0|MagicMir | [23.02.2022 10:19.19.442] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
      0|MagicMir | at App.stop (/home/pi/MagicMirror/js/app.js:257:14)
      0|MagicMir | at process. (/home/pi/MagicMirror/js/app.js:272:8)
      0|MagicMir | at process.emit (node:events:394:28)
      0|MagicMir | [23.02.2022 10:19.19.444] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [23.02.2022 10:19.19.445] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [23.02.2022 10:19.19.460] [ERROR] Whoops! There was an uncaught exception…
      0|MagicMir | [23.02.2022 10:19.19.462] [ERROR] TypeError: Cannot read properties of undefined (reading ‘close’)
      0|MagicMir | [23.02.2022 10:19.19.464] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [23.02.2022 10:19.19.465] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|MagicMir | [2488:0223/101920.289240:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      Dennis
      N6NGN 1 Reply Last reply Reply Quote 0
      • N6NGN Offline
        N6NG
        I have no problem with the internet connection at this time…
        Dennis
        • N6NGN Offline
          N6NG @N6NG
          @n6ng I’ve reinstalled it 3 times now with the same result.
          Just FYI.
          Dennis
          • N6NGN Offline
            N6NG
            Ok… I think I have identified a bigger problem. I have thus far loaded the following weather programs.
            MMM-OneCallWeather
            MMM-MyWeather
            MMM-DynamicWeather
            all with the same result… A blank screen when any of them are included in my MM. I do have the following modules working properly on my MM with no problem.
            alert
            updatenotification
            clock
            calender-check
            google-calendar
            MMM-RAIN-RADAR
            on-this-day
            newsfeed
            All working properly… When every I include any of the weather modules is when I get the blank screen… Hope this helps somehow.
            Dennis
              sdetweil @N6NG
              @n6ng see
              • N6NGN Offline
                N6NG @sdetweil
                @sdetweil I followed the instructions from the link you posted and found it could not find a file called axios. So I did the install of that program, and now my screen won’t stay on for more than a few seconds. It then goes black… I don’t know if it fixed my weather module or not…Now I get the error messages:
                0|MagicMir | [3417:0225/110146.538714:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|MagicMir | [3453:0225/110146.872192:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                The only thing I can think of doing is to start from scratch and try it all again…
                Before I do that, any suggestions?
                Thanks all…
                Dennis
                n6ngdennis@gmail.com
                  sdetweil @N6NG
                  @n6ng those are incorrect error messages… not the problem
                  • N6NGN Offline
                    N6NG @sdetweil
                    I found your message to vintage89 about the display in package.json
                    Apr 10, 2020, 3:20 PM
                    @vintage89 edit the package.json file and remove the display=${display… stuff from the start clause
                    It should start with "node_modules, like this
                    “start”: “node_modules/.bin/electron js/electron.js”,
                    Sam"
                    Did that myself and it seems to have fixed the problem… now back to the weather problem again… More to follow…
                    Thanks again Sam… you have some real words of wisdom throughout these many pages…
                    Dennis
                    S N6NGN 2 Replies Last reply Reply Quote 0
                      sdetweil @N6NG
                      @n6ng np. but you never said Windows…
                      • N6NGN Offline
                        N6NG @N6NG
                        @n6ng It wasn’t Windows… but it worked anyway.
                        Dennis
                          sdetweil @N6NG
                          @n6ng what is it? DISPLAY is an xwindows thing
                          • N6NGN Offline
                            N6NG @sdetweil
                            @sdetweil It is just a standard Raspberry Pi 3b with Debian with Buster and anASUS HDMI monitor…
                            But it was on for a couple of seconds and then off for 5 or 10 seconds back and forth… now it is back to normal…
                            Dennis
                              sdetweil @N6NG
                              @n6ng so display might be set in the environment already.
                              the code says set display to :0 if not set
                              that’s the normal default xwindows instance
                              • N6NGN Offline
                                N6NG @sdetweil
                                @sdetweil So are you saying that’s what I should set the display line to instead of what to said to set it to in this forum link?
                                If that’s true, I’ll try it…
                                Dennis
                                  sdetweil @N6NG
                                  @n6ng we are crossing topics
                                  that is
                                  won’t start on Windows, because DISPLAY=… on start function in package.json
                                  that is
                                  blank screen because of missing dependencies on some/many modules
                                  • N6NGN Offline
                                    N6NG
                                    Ok… going to build another and try again…
                                    Thanks Sam
                                    Dennis
                                    • N6NGN Offline
                                      N6NG
                                      Can’t figure out how to mark this as resolved but rebuilt it and it worked fine… Thanks
                                      Dennis
                                        sdetweil @N6NG
                                        @n6ng not opened as a problem , so can’t ‘close’ it
                                        • N6NGN Offline
                                          N6NG @sdetweil
                                          @sdetweil thanks
