    MMM-OneCallWeather
    24 Posts 2 Posters 8.3k Views 2 Watching
    • N6NGN Offline
      N6NG @sdetweil
      @sdetweil I followed the instructions from the link you posted and found it could not find a file called axios. So I did the install of that program, and now my screen won’t stay on for more than a few seconds. It then goes black… I don’t know if it fixed my weather module or not…Now I get the error messages:
      0|MagicMir | [3417:0225/110146.538714:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMir | [3453:0225/110146.872192:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      The only thing I can think of doing is to start from scratch and try it all again…
      Before I do that, any suggestions?
      Thanks all…
      Dennis
      n6ngdennis@gmail.com
        sdetweil @N6NG
        @n6ng those are incorrect error messages… not the problem
        N6NGN 1 Reply Last reply Reply Quote 0
        • N6NGN Offline
          N6NG @sdetweil
          I found your message to vintage89 about the display in package.json
          Apr 10, 2020, 3:20 PM
          @vintage89 edit the package.json file and remove the display=${display… stuff from the start clause
          It should start with "node_modules, like this
          “start”: “node_modules/.bin/electron js/electron.js”,
          Sam"
          Did that myself and it seems to have fixed the problem… now back to the weather problem again… More to follow…
          Thanks again Sam… you have some real words of wisdom throughout these many pages…
          Dennis
          S N6NGN 2 Replies Last reply Reply Quote 0
            sdetweil @N6NG
            @n6ng np. but you never said Windows…
            • N6NGN Offline
              N6NG @N6NG
              @n6ng It wasn’t Windows… but it worked anyway.
              Dennis
                sdetweil @N6NG
                @n6ng what is it? DISPLAY is an xwindows thing
                • N6NGN Offline
                  N6NG @sdetweil
                  @sdetweil It is just a standard Raspberry Pi 3b with Debian with Buster and anASUS HDMI monitor…
                  But it was on for a couple of seconds and then off for 5 or 10 seconds back and forth… now it is back to normal…
                  Dennis
                    sdetweil @N6NG
                    @n6ng so display might be set in the environment already.
                    the code says set display to :0 if not set
                    that’s the normal default xwindows instance
                    • N6NGN Offline
                      N6NG @sdetweil
                      @sdetweil So are you saying that’s what I should set the display line to instead of what to said to set it to in this forum link?
                      If that’s true, I’ll try it…
                      Dennis
                        sdetweil @N6NG
                        @n6ng we are crossing topics
                        that is
                        won’t start on Windows, because DISPLAY=… on start function in package.json
                        that is
                        blank screen because of missing dependencies on some/many modules
                        • N6NGN Offline
                          N6NG
                          Ok… going to build another and try again…
                          Thanks Sam
                          Dennis
                          • N6NGN Offline
                            N6NG
                            Can’t figure out how to mark this as resolved but rebuilt it and it worked fine… Thanks
                            Dennis
                              sdetweil @N6NG
                              @n6ng not opened as a problem , so can’t ‘close’ it
                              • N6NGN Offline
                                N6NG @sdetweil
                                @sdetweil thanks
