    MMM-OneCallWeather
    24 Posts 2 Posters 9.1k Views 2 Watching
    • N6NGN
      N6NG @N6NG
      @n6ng It wasn’t Windows… but it worked anyway.
      Dennis
        sdetweil @N6NG
        @n6ng what is it? DISPLAY is an xwindows thing
        N6NGN 1 Reply Last reply Reply Quote 0
        • N6NGN
          N6NG @sdetweil
          @sdetweil It is just a standard Raspberry Pi 3b with Debian with Buster and anASUS HDMI monitor…
          But it was on for a couple of seconds and then off for 5 or 10 seconds back and forth… now it is back to normal…
          Dennis
            sdetweil @N6NG
            @n6ng so display might be set in the environment already.
            the code says set display to :0 if not set
            that’s the normal default xwindows instance
            • N6NGN
              N6NG @sdetweil
              @sdetweil So are you saying that’s what I should set the display line to instead of what to said to set it to in this forum link?
              If that’s true, I’ll try it…
              Dennis
                sdetweil @N6NG
                @n6ng we are crossing topics
                found your message to vintage89 about the display in package.json
                Apr 10, 2020, 3:20 PM
                @vintage89 edit the package.json file and remove the display=${display… stuff from the start clause
                It should start with "node_modules, like this
                “start”: “node_modules/.bin/electron js/electron.js”,
                that is
                won’t start on Windows, because DISPLAY=… on start function in package.json
                that is
                blank screen because of missing dependencies on some/many modules
                • N6NGN
                  N6NG
                  Ok… going to build another and try again…
                  Thanks Sam
                  Dennis
                  • N6NGN
                    N6NG
                    Can’t figure out how to mark this as resolved but rebuilt it and it worked fine… Thanks
                    Dennis
                      sdetweil @N6NG
                      @n6ng not opened as a problem , so can’t ‘close’ it
                      • N6NGN
                        N6NG @sdetweil
                        @sdetweil thanks
