    MMM-OneCallWeather
    24 Posts 2 Posters 9.1k Views 2 Watching
      sdetweil @N6NG
      @n6ng np. but you never said Windows…
      • N6NGN
        N6NG @N6NG
        @n6ng It wasn’t Windows… but it worked anyway.
        Dennis
          sdetweil @N6NG
          @n6ng what is it? DISPLAY is an xwindows thing
          N6NGN 1 Reply Last reply Reply Quote 0
          • N6NGN
            N6NG @sdetweil
            @sdetweil It is just a standard Raspberry Pi 3b with Debian with Buster and anASUS HDMI monitor…
            But it was on for a couple of seconds and then off for 5 or 10 seconds back and forth… now it is back to normal…
            Dennis
              sdetweil @N6NG
              @n6ng so display might be set in the environment already.
              the code says set display to :0 if not set
              that’s the normal default xwindows instance
              • N6NGN
                N6NG @sdetweil
                @sdetweil So are you saying that’s what I should set the display line to instead of what to said to set it to in this forum link?
                If that’s true, I’ll try it…
                Dennis
                  sdetweil @N6NG
                  @n6ng we are crossing topics
                  found your message to vintage89 about the display in package.json
                  Apr 10, 2020, 3:20 PM
                  @vintage89 edit the package.json file and remove the display=${display… stuff from the start clause
                  It should start with "node_modules, like this
                  “start”: “node_modules/.bin/electron js/electron.js”,
                  that is
                  won’t start on Windows, because DISPLAY=… on start function in package.json
                  that is
                  blank screen because of missing dependencies on some/many modules
                  • N6NGN
                    N6NG
                    Ok… going to build another and try again…
                    Thanks Sam
                    Dennis
                    • N6NGN
                      N6NG
                      Can’t figure out how to mark this as resolved but rebuilt it and it worked fine… Thanks
                      Dennis
                        sdetweil @N6NG
                        @n6ng not opened as a problem , so can’t ‘close’ it
                        • N6NGN
                          N6NG @sdetweil
                          @sdetweil thanks
